Page 135 of 172 FirstFirst ... 3585125130131132133134135136137138139140145 ... LastLast
Results 2,011 to 2,025 of 2578
  1. #2011
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by javyb View Post
    Is it possible to generate a key for Mercedes sprinter w906 by ezs eeprom file?when I try load ezs file it says incorrect file
    Sent from my SM-N960F using Tapatalk
    I guess you have Sprinter 2014+. Because there is a little bit different eeprom structure on these and need to change some lines in order to file being accepted by calculators.
    Post dump and someone will do it surely.
  2. The Following 2 Users Say Thank You to p1et For This Useful Post:
    ASCM (21st May, 2020), javyb (20th May, 2020)
  3. #2012
    Is it possible to renew W245 B-Class CDI engine control unit with CGDI?
    Best Regards
  4. The Following User Says Thank You to papalos_ For This Useful Post:
    trinicolin (24th May, 2020)
  5. #2013
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
  6. The Following User Says Thank You to figani For This Useful Post:
    jaelgti (8th June, 2020)
  7. #2014
    CG-MB BenzMonster V3.0.1.0 NEW
    (2020.05.28)
    1. Added CGDI MB keyless go key (76 version) resetting function.
    2. Added the function of reading new BGA key to get EIS data.
    3. Added operation tutorial viewing function.
    4. Added Russian language. (Need to be authorized by dealer).
    5. Added W203 ELV writing function.
    6. Added the new W164 EIS (special) all key lost collection function. (The number of this W164 EIS is 164545, but the casing is new.)
    7. Optimized interface layout and fixed BUG.
  8. The Following User Says Thank You to u.s For This Useful Post:
  9. #2015
    Top Poster kristikapa's Avatar
    Anyone tried FBS4 mileage function?
    THX
  10. The Following User Says Thank You to kristikapa For This Useful Post:
    igorr (3rd June, 2020)
  11. #2016
    please i need erase pass for w212 eis renew special key - 4A03EEA9DFDE4DD8
    THANKS
  12. #2017
    Jun 2013
    where file?
  13. #2018
    Mar 2018
    Finally I have fixed this kind of problem.
    Programmed 8 new keys to all slots, all working and drive.
    Re-program new key to used key slot also working w/o any problems.
    Renewed eis elv and programmed new keys also working.
    Tested with VVDI and CGDI key all are good.
  14. The Following User Says Thank You to babeh For This Useful Post:
    rob h (18th June, 2020)
  15. #2019
    What was the solution in your case?
  16. #2020
    mr G's Avatar
    Sep 2019
    hello, CGDIMB showing "Sorry, Erase Password not found". Can someone help me please with erase password? Why Password is not found? Special key 0DC6A7E527DFE066
    THANKS
    Edit: Done cloning with VVDI Prog.
  17. #2021
    p1et's Avatar
    Oct 2013
    Useful option for this tool would be possibility of reading key pass from NEC V57 which is available in any other MB tool on market (avdi, vvdi etc.)
  18. The Following 2 Users Say Thank You to p1et For This Useful Post:
    bocaje (20th June, 2020), sepistar (19th June, 2020)
  19. #2022
    Apr 2016
    Quote Originally Posted by babeh View Post
    Solution was?
    Enviado do meu iPhone usando o Tapatalk
  20. #2023
    Mar 2018
    Quote Originally Posted by bocaje View Post
    Solution was?
    I have been asked months about this but no one has idea.
    The best way, renew ECU TCU EIS ESL, write EIS with old/new EIS data, then learn drive authorization.
    You need C4 SDconnect.
    I believe there are many ways to fix it.
  21. The Following 2 Users Say Thank You to babeh For This Useful Post:
    bocaje (22nd June, 2020), rob h (8th July, 2020)
  22. #2024
    Cepe Verde
    i have to tell my firs time i use tis tool. Key was damaged i had calculated all keys files and wait to have new keys. I was playing aroud with erasing eis than software crashed. I try to reinstall the software without saving the files in other forlder. than i lost all. now i need to recover the eis and write new keys. they told me i need eis data from the same car or the same eis number A2125450108. Car vin WDD2120721A050141. i'd like some one to help me wit a similar file. i have c4 tool so i can readapt eis again. tey told me to read eis again with 120ohm resistence. i will try. when i read with IR key of cgdi i get no km no vin but eis is not damaged and micro is ok. Lodade data from the car is lost. Help me please. thanks in advance
  23. #2025
    Mar 2018
    Quote Originally Posted by ssemmedo View Post
    you should save data before doing anything especially renew and erase.
    Hopefully you still able to get back all the data from car.
    Do you familiar with C4 ?
    Have your write down the key password or you've just erase EIS ?
    If you have calculated new keys you should have EIS data and key password, right ?
