Page 136 of 178 FirstFirst ... 3686126131132133134135136137138139140141146 ... LastLast
Results 2,026 to 2,040 of 2659
  1. #2026
    Nov 2010
    Quote Originally Posted by babeh View Post
    you should save data before doing anything especially renew and erase.
    Hopefully you still able to get back all the data from car.
    Do you familiar with C4 ?
    Have your write down the key password or you've just erase EIS ?
    If you have calculated new keys you should have EIS data and key password, right ?
    Standard Benzmonster did save all data in the directory it is installed.
    If you upgrade the software then it will delete all before installing the new revision.
    So, if you do not save it else where yourself then all is lost...
  2. #2027
    Mar 2018
    Quote Originally Posted by Msmax View Post
    My data files are also saved in the same directory with Benzmonster,
    the update process will not delete other files and directories,
    I have tested several times.
    of course I have also do backup all my data.
  3. #2028
    Cepe Verde
    in my case all data was lost when trying to reisntall the software after crash of monster. Now they told me to read dash, ecu, renew all and try to adapt again with new eis file. i will try to do so. I have c4 to make all. hope i can do it.
  4. #2029
    rob h's Avatar
    May 2011
    Hello guys,
    Dealer eis, states cgdi. W639 Vito 2004.
    I can calc erase and wipe the eis.
    However write vin and write eis data fail.
    I need to change the immo data in R2.
    (R1 km and vin is not realy the problem)
    (I did this, a few days, on a similar vito eis. No problems.
    (loaded C203 immo data in a W639 eis, worked)
    What does dealer eis mean? Could i overwrite the R2 immo with a donor,, non dealer ,,eeprom file?
    So that i can renew, write, and activated it.
    Or is there more to it?
    Vito 2004 eis A6395450608 6395450608 2M73Y S908AZ60ACFUE
    R1 sec byte
    DFC8EA48EA48EA48
    DF-C8-EA-48-EA-48-EA-48
    R2 sec byte
    BF2FCD68CD68CD68
    BF-2F-CD-68-CD-68-CD-68
    vito ezs prog.rar
  5. The Following User Says Thank You to rob h For This Useful Post:
    serikpay (22nd August, 2022)
  6. #2030
    Dealer eis mean that is eis changed by dealer not original one
  7. The Following User Says Thank You to antibisic For This Useful Post:
    rob h (27th June, 2020)
  8. #2031
    rob h's Avatar
    May 2011
    Thank you, i read something about this. Mostly taxi have this.
    How do i cheat, to get what i want?
    Read about poldiag being able to do these.
    Is this dealer eis, only a immo eeprom thing?
    Would writing a regular immo eeprom with programmer fix this?
    I can not write a different flash, with a programmer.
    So, is there a eeprom dump, non dealer that allows me to renew and activated this eis?
  9. #2032
    try it,nothing to loose
  10. The Following User Says Thank You to antibisic For This Useful Post:
  11. #2033
    rob h's Avatar
    May 2011
    I have now written both eeproms, with a few files i found on D.K.
    Still dealer eis is checked.
    So must be in the roms.
  12. The Following User Says Thank You to rob h For This Useful Post:
    antibisic (28th June, 2020)
  13. #2034
    please i need erase pass for w204 steering lock special key - 4AF8AD2D3B2E037E .
    Thanks.
  14. #2035
    p1et's Avatar
    Oct 2013
    I have a faulty key for W210. I'd like to know what exactly might it be, is NEC somehow wiped or what? CGDI read key every time, just status and other things are messy, have a look:
  15. #2036
    hi guys can someone please calculate erase password for me CGDI cant find it thanks
    ECU A651 150 18 79
    SPECIAL KEY 40 0C BD F1 A4 98 35 47
  16. #2037
    rob h's Avatar
    May 2011
    Hello P1et,
    Dirty ir parts, in key, and ezs.
    Use a cuetip, to clean lock, and inside of key towards red glass.
    And dont put the cgdi direct in the sunlight, this will mess up reading.
    Found this out, years ago on a sunny day. Even a garage portable led light, or smartphone led could send out some distorting ir waves.
  17. The Following User Says Thank You to rob h For This Useful Post:
    p1et (4th July, 2020)
  18. #2038
    Quote Originally Posted by abdulrauf View Post
    Thanks.
    63A0B31E48AA8DFA
  19. #2039
    Quote Originally Posted by iky786 View Post
    ECU A651 150 18 79
    037A3B47DA51BFE9
  20. #2040
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by rob h View Post
    Hello P1et,
    I resoldered all the components on PCB but still same bullsh1t result when reading via IR. I think NEC lost it's data somehow.
