Page 137 of 172 FirstFirst ... 3787127132133134135136137138139140141142147 ... LastLast
Results 2,041 to 2,055 of 2578
  1. #2041
    rob h's Avatar
    May 2011
    Hello P1et,
    Have you tried, activating the key, using the eis password.?
  2. #2042
    rob h's Avatar
    May 2011
    https://www.digital-kaos.co.uk/forum...ng#post3849275
    Last week, this car came back, W204 with computing data in screen.
    So i now renewed the eis, using cgdi.
    Then the odometer jumped up about 200.000 kilometers.
    Car starts.
    The computing data, whas still there.
    The owner, had only 1 key left from the 2 i made before.
    So i made a new, inserted it in the eis.
    Not working, i could turn it in the eis, but no dash came on.
    Except the remote did worked.?!?!?!?
    So i activated this new key, using pass from eis, and it started the car.
    Still with the computing data in the screen.
    (I am getting me a used eis, same numbers, and will program that one in.
    I came across another W204 yesterday, with dealer eis, how comen is this? and will there be a solution for this from Cgdi?
    To renew dealer eis,)
  3. #2043
    Mar 2018
    Quote Originally Posted by rob h View Post
    Car starts.
    Something similar to my case. https://www.digital-kaos.co.uk/forum...=1#post3889808
    You will need C4.
  4. The Following User Says Thank You to babeh For This Useful Post:
    rob h (10th July, 2020)
  5. #2044
    Mar 2019
    Moldova
    I changed the infrared diode to a new one and found that it is too sensitive to the light source. If a lamp shines on the table, then the self test does not pass, also in bright sunshine. What do you advise?
  6. #2045
    rob h's Avatar
    May 2011
    Quote Originally Posted by tankist83 View Post
    This is normal, even with gen 1 infrared.
    The light, will shine treu the red plactic cover.
    Not the space between key, and cgdi Ir insert.
    Cut a mask, and place this over the device.
    If this works, place this mask inside the cgdi itself.
  7. The Following User Says Thank You to rob h For This Useful Post:
    tankist83 (8th July, 2020)
  8. #2046
    Mar 2019
    Moldova
    Thanks. I will try it.
  9. #2047
    Mar 2018
    Quote Originally Posted by niksata90 View Post
    CGDI can't read the eis A203 545 01 08 with ac adapter (only read with IR is possible)
    I read the eis with prog on bench, generate keys with cgdi and add new key
    Your PM is full !
    Nobody can reply !
    Clean your box!
    About your question, you need C3 or C4, and should have some knowledge using DTS or Vediamo.
  10. The Following User Says Thank You to babeh For This Useful Post:
    niksata90 (12th July, 2020)
  11. #2048
    please i need erase pass for 276 ecu, special key - 90AA0AB2404DBD53 .
    THANKS
  12. #2049
    Does anyone have meter adapter? It is interesting to see what is in it, what pinout of contacts in it ....
    For my bad English - scold GOOGLE translator...
    Don`t forget to use
    Thanks button and reputation
  13. #2050
    please am in hot seat, please help i need erase pass for 276 ecu, special key - 90AA0AB2404DBD53 .
    THANKS
  14. #2051
    Aug 2010
    hello,
    can someone please help me to generate a key.
    dump is from W211 EIS
    my target key is .041 (mask OF82B)
    thanks in advanceHollowman1701.zip
  15. #2052
    Quote Originally Posted by abdulrauf View Post
    THANKS
    EB4A2AFFCD70F877
  16. #2053
    Quote Originally Posted by Hollowman1701 View Post
    hello,
    here are your keys
  17. The Following User Says Thank You to ficho For This Useful Post:
    Hollowman1701 (15th July, 2020)
  18. #2054
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Maybe it's helpful for somebody...
    Mk3 Emirateskeys...
    W204/W212/W207 ELV Emulator...
    Like on the picture shown...
    With CGDI SW Version 3.0.2.0 are not longer WORKING and or compatible...
    You can still read them 100%...
    But writing not possible, failed...
    I tested alone 6 of them on three different cgdi HW, with SW 3.0.2.0, always same result...
    On older SW Versions it should still work longer...
    Same problem is with actual AVDI SW.
    Mk3/Emiratekeys know this problem, but until now they don't want exchange advertisement and or description.
  19. #2055
    rob h's Avatar
    May 2011
    Dont choose write emulator, choose write normal elv.
    And use bench setup, to write these if in car fails.
    Quote Originally Posted by figani View Post
    Mk3 Emirateskeys...
