Staafonline (11th August, 2020)
I use mb cdgi on mercedes c class 204 to correct mileage. When I write the mileage to dash,mileage is now reading 999999. Why has it done this and can anyone help please. I try a few times but dash reads the same
Because the maximum mileage in the eis is 999.999 miles.
And your cluster syncs mileage with eis.
Read eis mileage, and go from there
radiosolutions (13th August, 2020)
Please i need erase pass for elv w204.
Special key 24 AC 45 77 6A 9B 64 1F
Doing mileage correction is tricky,
only use write mileage direct to dash, other method will write a hacked flash to CGW,
but that won't work properly and you will get 999k mileage and will also ruin coding in your car.
You need to correct mileage in EIS... at the end then correct dash...
that is tricky.
After that, you may need C4 (or C3) with development engineering tool to correct ASSYST data and mileage in other control module,
otherwise the dash will have faults said management data and mileage incorrect misconfigurate untrust etc... of course that faults can be ignore.
REgards
If it corrupts the software why do cgdi programmer have this function on. What is best way to sort this out please
The problem is not the software. This function works proper.
You need to backup dash and gateway.
Then check real mileage first in eis.
Learn about the synch, and how to disable synch.
Buy a bench setup cable, so you can work on each module separete.
radiosolutions (14th August, 2020)
Trying to read a 2002 clk w210 on bench with ac adapter according to cgdi diagram. Reads eis data and then does the data collect but gives error on validation when uploaded. Am I supposed to do it in the car with Kline hooked up to ELV plug or something?
Hello guys
Why can't get erase password for ecu?
This the forth one for w211 can't get it.... Any problem with server?
Sent from my HTC U11 using Tapatalk
Actions speak louder than words
Is it possible to program CG keyless key for W219 CLS 2005? I heard those keys work only for 2007+ models but whats the difference?
