Page 141 of 178 FirstFirst ... 4191131136137138139140141142143144145146151 ... LastLast
Results 2,101 to 2,115 of 2659
  1. #2101
    Mar 2018
    it is difficult to read the photo
    Anyway if the EIS not renewed (erased) you can't write VIN !
    And your photo shows EIS already Activated.
    Let's force on why erase fail.
    What was happening when you insert the emulation key ?
    More details, more...
  2. #2102
    honingkoning's Avatar
    Dessert
    Quote Originally Posted by babeh View Post
    Sorry about the pictures on my phone they look a lot better :-)
    I cant write vin and eis is not activated its hard to see on this bad image.
    I tried to wipe eis and i get message erase eis error, i read eis again and all keys are deactivated and the eis is not activated anymore.
    When i tried to write data back to eis it refuses to write.
    When i insert emu key i can only see the red light on the emu key but nothing happens.
    After 10/20 sec the message pops up with the error eis failed.
    Tommorow i will trie to do this on the desk,maybe eis is not clearded good,is there a possibillity to activate this by eeprom or clear eis by eeprom or restore cgdi data to eeprom (i mean direct by programmer)
    Thanks guys.
  3. #2103
    Feb 2020
    Can someone please explain what is so special about dealer EIS that CGDI can not write to it?
    I know about the checkbox, I know CGDI can not write back to it, I'd like to know why.
    Thank you
  4. #2104
    Dessert
    Ok guys i removed cgw and eis from the car, and performed procedure for 10 or maybe 20 times on table again, finally i get message write eis data succes :-)
    Then i did key learning on table, mount all back to the car insert keys and after 5 or 10 sec you can hear elv moving, car running again.
    thanks guys.
  5. #2105
    Dec 2016
    So did u find out what was wrong?
  6. #2106
    Dessert
    Quote Originally Posted by 111arm View Post
    No maybe because I tried it out of the car, or because I kept trying 20 times.
    Really not sure
  7. #2107
    Mar 2018
    Quote Originally Posted by honingkoning View Post
    thanks guys.
    glad to see that work for you.
    sometimes working in car may fail due to gateway problem or OBD connection problem in car.
  8. #2108
    ttzag's Avatar
    digital-kaos
    Cgdi can only renew tcu 7g tronic..... How we can write vin on it?
    Sent from my HTC U11 using Tapatalk
    Actions speak louder than words
  9. #2109
    Jan 2018
    Quote Originally Posted by ttzag View Post
    I do it with vediamo.
    Отправлено с моего SM-N975F через Tapatalk
  10. #2110
    Mar 2018
    CGDI is useful but still not a coding tool.
    If you can only do coding offline, need to use C4 with Vediamo or DTS.
    This is already the lowest cost in doing coding, but need some knowledge.
  11. #2111
    Mar 2018
    recently we can do calculation (key and pass everything) in CGDI for free without counting any quota and token.
    Now they have fixed this 'bug', token is counting again.
  12. #2112
    ASCM's Avatar
    Oct 2018
    Quote Originally Posted by VitalyR133 View Post
    How can i use vediamo for coding
    And flashing ecm or tcm
    Can explains the steps
    Thanks in advance
    Sent from my SM-J415F using Tapatalk
  13. #2113
    Mar 2018
    Quote Originally Posted by ASCM View Post
    Thanks in advance
    This is difficult topic if you have zero knowledge in it.
    1. you need proper hardware to make connection to your MB car, like C3...C4...etc.(not CGDI)
    2. you need proper setup that your computer and Vediamo can communicate with your car
    3. you need correct files that use in Vediamo can communicate to car modules (eg.ecu tcu sam esp hu ... ic eis etc.)
    4. after you solve the above, you can start coding... but need to know what the coding looks like!
    For TCU ECU need also teach-in the drive authorization, do calibration etc.
    Wrong coding result tons of fault codes(DTC), damage the engine and tranmission and the worst car run in lim mode or not start.
    Actually Vediamo can't do everything, some other software tools will also needed,
    The best easy way is do online SCN coding, if you have Mercedes account.
    There is no step by steps can explain all these.
    and this is already off topic.
  14. #2114
    please i need erase pass for ecu special key- 7BF15B1640AAA863 .
    THANKS
  15. #2115
    ASCM's Avatar
    Oct 2018
    I need to use vediamo for unlocking fbs4 ecu
    I have vas 5054 pasthru for 4.2.2 vediamo
    Sw but i dont have database for it can you help me via teamviewer for adding flash and coding database in vediamo folder and seed key calculator ?
