Page 147 of 178 FirstFirst ... 4797137142143144145146147148149150151152157 ... LastLast
Results 2,191 to 2,205 of 2659
  1. #2191
    Mar 2015
    UA
    Here are screenshots of the read password from the key after SGDI and after the Mercedes instrument.
    Try to write this dump as an option.
  2. The Following User Says Thank You to MVVL For This Useful Post:
    p1et (8th January, 2021)
  3. #2192
    Dec 2014
    chk folder of keys genarated
  4. #2193
    The last batch of CG keys was not read or written to the CGDI MB. The manufacturer CGDI MB recommends replacing the IR receiver and transmitter. There was neither time nor desire to buy it and wait. Therefore, I tried to install the IR receiver and transmitter from an old faulty original key. Now CGDI MB reads and writes perfectly again !!!
    For my bad English - scold GOOGLE translator...
    Don`t forget to use
    Thanks button and reputation
  5. The Following 8 Users Say Thank You to EduardNN For This Useful Post:
    111arm (18th January, 2021), antibisic (8th January, 2021), bocaje (8th January, 2021), bram380 (17th January, 2021), hesham10 (20th January, 2021), igorr (19th January, 2021), jodge (9th January, 2021), taxo1965 (2nd May, 2021)
  6. #2194
    Apr 2016
    Quote Originally Posted by EduardNN View Post
    I agree but i just use the bord and hold it vertical and went ok.
    Thanks for feedback.
    Enviado do meu iPhone usando o Tapatalk
  7. #2195
    jodge's Avatar
    Mar 2017
    on the right side it's a resistor?
  8. #2196
    Quote Originally Posted by jodge View Post
    That's clearer?
    Don`t forget to use
  9. The Following 4 Users Say Thank You to EduardNN For This Useful Post:
    bram380 (17th January, 2021), jodge (9th January, 2021), lion0304 (10th January, 2021), sepistar (30th January, 2021)
  10. #2197
    Shmortz's Avatar
    in the middle of nowhere
    I need help with erase password for W211 ELV, special key: 96D9C15296D9C152
  11. #2198
    lion0304's Avatar
    Oct 2014
    That's clearer?
    Very useful experience, did you use to write Xhorse and CGDI Keyless Go by IR?
    Because CGDI manufacturer said need change to write these keys.
  12. #2199
    Quote Originally Posted by lion0304 View Post
    Regular keys labeled CG. Of the five keys, only one key was recorded from the fifth time. After replacing IR light and photo diodes, the keys can be read and written without problems.
    Don`t forget to use
  13. The Following User Says Thank You to EduardNN For This Useful Post:
    lion0304 (11th January, 2021)
  14. #2200
    Quote Originally Posted by Shmortz View Post
    HI,
    Here is a valid password for you: 40AE977E6407FCA1, 8E5B34D565F7061B, D6EDB5EC7829E40A <-- This is a Valid Pass Hash
    any of above should fit.
    regards
    pc: I just saw the dump has swapped bytes comparing to the special key you have written:
    so this should be ok if the first one doesnt fit D6739D2FB6CBEFEF, E4ECA96F208C5265, AA10180D1074AE31 <-- This is a Valid Pass Hash.
  15. The Following 2 Users Say Thank You to ficho For This Useful Post:
    bram380 (17th January, 2021), Shmortz (10th January, 2021)
  16. #2201
    Shmortz's Avatar
    Thank you, I will try tomorrow, dump and special key are saved from CGDI and uploaded as is...
  17. #2202
    May 2016
    romania
    you must specify what dme it is !!!
  18. #2203
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by MVVL View Post
    So that was the issue. I calc keys using your password from MI and all work.
    I knew AVDI at some point (or maybe still have?) had problems with incorrect password from dump of W169 / W245 but I done couple of those from dump read by vvdi prog / xprog and then calc by CGDI and every time it worked so at first I exclude wrong password and I was just fooled, didnt know what to do.
    Seems like there is some specific W169 / W245 EIS number which causes that problem.
    Thanks for help and sorry for late reply.
  19. #2204
    Apr 2016
    Hello
    If possible any idea or help.
    X164 read ok obd pass generated ok (I think)
    Keys generated ok.
    Already try 3 positions and key cranks but no start.
    Original key ok
    Remotes ok.
    What can it be or what could be the problem.
    No keyless system, and auto gearbox, eis already with nec so no normal read by direct vvdiprog or something.
    The car year is 07.
    Thanks for help if possible.
  20. #2205
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by bocaje View Post
    Hello
    Keys generated ok.
    Original key ok
    Remotes ok.
    The car year is 07.
    Most likely keys problem. W164 cause most trouble with china 'BE' keys. However in last summer I programmed one CG key and one original NEC to W164 and everything good on both, no any call back about CG key having troubles to this day.
  21. The Following User Says Thank You to p1et For This Useful Post:
    bocaje (1st February, 2021)
