Page 150 of 178 FirstFirst ... 50100140145146147148149150151152153154155160 ... LastLast
Results 2,236 to 2,250 of 2659
  1. #2236
    May I've the erase password for W204 ELV:
    Special Key: 4D F5 FC C1 14 BB 74 A6
    Best Regards
  2. #2237
    s qubiak's Avatar
    Jun 2017
    Polska
    Hello.
    Med17.7.2 erase problem
    power 12.7V 13.2V 14.5V
    did not work
    any ideas ?
    thx
    possible virgin?
    read vvdi prog d flash and p flash
    IF I HELPED YOU, PLEASE REMEMBER TO PRESS THANKS AND REPUTATION.
  3. The Following User Says Thank You to s qubiak For This Useful Post:
    hesham10 (9th January, 2023)
  4. #2238
    Apr 2016
    Hello
    Can anyone help device not found message change cable usb and check usb etc no go.
    Green light on but device does not conect.
    Enviado do meu iPhone usando o Tapatalk
  5. #2239
    Oct 2018
    egypt
    Quote Originally Posted by s qubiak View Post
    Hello.
    did not work
    any ideas ?
    thx
    possible virgin?
    Anybody here done med17.7.2 successfully?
    wbr.
  6. #2240
    Mar 2018
    Quote Originally Posted by papalos_ View Post
    Is CGDI tech support alive???
    Could you please add support for Xhorse Mini ELV simulator on next update? CGDI is not be able to handle this type of simulator! I'm trying to program it as a normal ELV and the steps seem to be done successfully. But in reality nothing changes in the data of the simulator and finally cannot be activated.
    Best Regards
    Just program it as normal ESL,
    NOT in 'ELV simulator'.
    After programmed, read ESL only give you the wrong data, read is not support by those emulator, not the problem of CGDI or VVDI.
    just insert working key to activate.
  7. #2241
    Mar 2018
    I am not fans of those tools, but cgdi is affordable and do the job I needed.
    Worked on cgdi mb keys and keyless key, vvdi mb keys and keyless key, mk3 ELV emulator etc.
    Renew ECU TCU, and correct dash mileage.
    (just use direct write mileage with coding, those soft/hard CAN filter are s.ucks)
    No problems so far!
    No keys problem, no elv problems or any other problems.
  8. #2242
    Is the server running?
    For my bad English - scold GOOGLE translator...
    Don`t forget to use
    Thanks button and reputation
  9. #2243
    Jun 2019
    Quote Originally Posted by EduardNN View Post
    No, i had troubles earlier with the server and contacted support they are resynchronzing data on server. Might take a while.
  10. #2244
    Mar 2019
    Moldova
    Who can help me? I read the w211 lock dump using R270 but now CGDI mb says that the file is not correct.
  11. #2245
    Quote Originally Posted by tankist83 View Post
    Change the file name, for example 211.bin
    Don`t forget to use
  12. #2246
    Mar 2019
    Moldova
    Thanks. All work.
  13. #2247
    Mar 2018
    But upload data not work.
    upload to generate key files is working,
    get erase password working
  14. The Following User Says Thank You to babeh For This Useful Post:
    tankist83 (19th March, 2021)
  15. #2248
    Mar 2019
    Moldova
    Quote Originally Posted by babeh View Post
    Yes all work. Thank you.
  16. #2249
    Mar 2018
    ** note **
    There is one batch of CGDI ESL emulator has problem !
    Those CGDI ESL able to read and write,
    But FAIL to activate so car can't start !
    If you have this kind of ESL emulator keep failing,
    check your buyer for return and replace.
  17. #2250
    Member spiria's Avatar
    Belarus/Grodno
    Hi all.
    Maybe anyone have schematic this cable? CGDI MB 205 Extend Board for FBS4 Instruments Meter Adapter
