Page 151 of 178 FirstFirst ... 51101141146147148149150151152153154155156161 ... LastLast
Results 2,251 to 2,265 of 2663
  1. #2251
    Quote Originally Posted by babeh View Post
    Just program it as normal ESL,
    NOT in 'ELV simulator'.
    After programmed, read ESL only give you the wrong data, read is not support by those emulator, not the problem of CGDI or VVDI.
    just insert working key to activate.
    Please, take a look on this photo story i created with whole process. As you can see at the end, the ELV is not activated.
  2. #2252
    May 2013
    can one of you help me with password from dump w207 eis thanks in advance
    WDDGF8BB6BR149687_2021_03_29_11_18_2.rar
  3. #2253
    May 2013
    i was able to do it
  4. #2254
    Mar 2018
    Quote Originally Posted by papalos_ View Post
    Do you have other (type) emulator can try ?
    I don't have this new emulator so can't tell what's wrong.
    Can you also show EIS read screen ? is the EIS activated ?
    Or maybe try renew EIS, sync to ELV, see if this work ?
  5. The Following User Says Thank You to babeh For This Useful Post:
    papalos_ (31st March, 2021)
  6. #2255
    honingkoning's Avatar
    Dessert
    Maybe the same like the cheap mk3 ones, program says not activated but led lights up green and works great.
    Did you tried it in the car
    Verstuurd vanaf mijn ANE-LX1 met Tapatalk
  7. The Following User Says Thank You to honingkoning For This Useful Post:
  8. #2256
    Mar 2018
    Maybe this is the case.
    In reading MK3 emulator it won't show anything meaningful,
    but actually it is working.
    You can use "Check EIS status" to see if ELV working or not.
  9. The Following User Says Thank You to babeh For This Useful Post:
  10. #2257
    No I don't other emulator type. Only a few genuine ELV and 5 x Xhorse mini emulators.
    EZS is activated. I test the same EZS with genuine ELV and it works.
    Anyway, I'll try your suggestion.
  11. #2258
    I've only done tests on the bench. I haven't tried it in on vehicle. "Check EIS status" shows only mechanical status as ticked during key rotation, car status remains blank.
  12. #2259
    Mar 2018
    If you have EIS/ELV test cable or testing platform you can test it on bench.
    You are working on bench you should also able to test it on bench, do you ?
  13. #2260
    Yes I have cable set and I'm testing EZS-ELV-Key on bench. I don't understand the question.
  14. #2261
    Mar 2018
    If you have other ELV or maybe the original working ELV then you can confirm your test cable wired and is working properly.
    When checking EIS status and if you not getting 15R tick,
    means either the ELV not programmed or not working or not connected properly or other problems.
    Maybe I will get that mini ELV later to see how is it.
  15. The Following User Says Thank You to babeh For This Useful Post:
    papalos_ (7th April, 2021)
  16. #2262
    2007 Mercedes GL320 W164 all keys lost is it enough with just ezs using the CGDI AC adapter or must i have the gateway aswell to do on bench
    Sent from my SM-N960F using Tapatalk
  17. The Following User Says Thank You to javyb For This Useful Post:
    p1et (7th April, 2021)
  18. #2263
    Mar 2018
    Quote Originally Posted by javyb View Post
    If you look into the wiring diagram no gateway is needed.
    But there are two type of EIS.
    Have you tried ?
  19. #2264
    Jun 2017
    US
    Tried to make a keyless go key to a 2008 w211. Keyless function doesn't work. Used VVDI keyless go key. Any tips?
  20. #2265
    Dessert
    Quote Originally Posted by darknezz19 View Post
    Did you make key type 41?
  21. The Following User Says Thank You to honingkoning For This Useful Post:
    martinez9049 (2nd May, 2021)
