Page 154 of 178 FirstFirst ... 54104144149150151152153154155156157158159164 ... LastLast
Results 2,296 to 2,310 of 2659
  1. #2296
    Feb 2014
    Quote Originally Posted by centrohifi View Post
    "INFO" read EZS W169 with R270 ... ALK lost. Read ok .. PW ok ... program new Key ... but it does not work.
    I put an ELV emulator and led turns green but key won't turn.
    Is it a key problem? or not to work with reading R270 ?!
    ThK
    Is the key you used in good condition? Second hand original or BE key - what did you use?
    Is key activated now?
  2. #2297
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    Quote Originally Posted by autoTkey View Post
    today arrive new key. To try. also get Gateway to program key, as described in CGDI ...
    ..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
  3. #2298
    Feb 2020
    PLEASE HELP 204 used elv adaptation
    hi i need some help...i saw the tutorials but they seem contradicting...i wiped second hand w204 elv...then wiped the eis...wrote back the saved data and then synced the evl from the eis tab...only when i read the evl data all seems in order but the activated tab remains unticked....is that typical or am i doing something wrong?
    also saw a video on youtube where a guy simply wipes the evl then writes the eis data? it worked for him....what it the correct procedure?
  4. #2299
    ELV will not activate until a valid key is inserted in EZS, this means a lock unlock cycle should be preformed.
  5. #2300
    Quote Originally Posted by thesithlord01 View Post
    i still cant collect data from this EIS even after turning the key, all my connections are according to the cgdi mb wiring diagram with fast collection adapter. PLS HELP !
    Friend, did you watch me do it?
    For my bad English - scold GOOGLE translator...
    Don`t forget to use
    Thanks button and reputation
  6. #2301
    May 2021
    Mercedes sprinter 2009 can cgdi add a key on obd or do I need to disassemble eis or ezs
  7. #2302
    Nov 2019
    Quote Originally Posted by godfathertwo View Post
    W906 2017 added by obd
    Wysłane z mojego SM-N986B przy użyciu Tapatalka
  8. The Following User Says Thank You to Kotgacek For This Useful Post:
    godfathertwo (27th June, 2021)
  9. #2303
    May 2021
    But this model is 2009 older has anybody added a key or key lost on this van.
  10. #2304
    honingkoning's Avatar
    Dessert
    2017 same car mate all fbs 3.
    AKL need to disassemble eus otherwise 10 min by obd
    Verstuurd vanaf mijn ANE-LX1 met Tapatalk
  11. The Following User Says Thank You to honingkoning For This Useful Post:
  12. #2305
    Nov 2019
    Cgdi will work for sure
  13. The Following User Says Thank You to Kotgacek For This Useful Post:
  14. #2306
    Mar 2018
    Quote Originally Posted by arnopypers View Post
    It is so simply, have you watch and understand those steps ??
    1. read EIS and get key password, save the EIS data.
    2. wipe both ELV and EIS
    3. write EIS data to EIS (don't insert key after write completed)
    4. sync ELV with EIS
    5. insert key, that will activate both EIS and ELV.
  15. The Following User Says Thank You to babeh For This Useful Post:
    arnopypers2 (2nd September, 2021)
  16. #2307
    ASCM's Avatar
    Oct 2018
    Does anyone can help me I want to change eis w169 does anyone can help me with steps ?without opening the eis !
    Sent from my 5033F using Tapatalk
  17. #2308
    Jul 2018
    united kingdom
    any one else happy with the tool?
  18. #2309
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by adisonic View Post
    154 pages are not enough to observe that or you still need 'any one else' than those users to be happy with this tool?
  19. #2310
    Mar 2018
    maybe need to define what is happy ?
    In my point of view it work as described, it do its job quite well.
    then maybe the most important, have already earned the cost of it,
    so should be happy.
    I have used it to write new MB keys, new keyless MB keys, (used vary brand of MB keys)
    renew and replace EIS, ESL and ESL emulators,
    renew ECU and TCU, (coding is needed after renew)
    calibrate dashboard correct mileage (without CAN filter) etc.
    It works what I needed.
    Are you having problem using it ?
