Page 162 of 178 FirstFirst ... 62112152157158159160161162163164165166167172 ... LastLast
Results 2,416 to 2,430 of 2659
  1. #2416
    Mar 2018
    Quote Originally Posted by kostin View Post
    Anybody have troubles with ELV emulator from CGDI or work alwayes well?
    I am using others ELV emulator, working very well.
    CGDI ELV emu also works well, but heard that some old batch has problems.
  2. #2417
    hi all. does anyone have this adapter? I would like to know the pinout. Thanks
  3. #2418
    Friends, no one has this adapter?
  4. #2419
    please i need erase pass for w203 ecu , special key - D0 BD 4C 3F 3B DA 68 9C .
  5. #2420
    Quote Originally Posted by abdulrauf View Post
    9D126B562D8601C0
  6. The Following User Says Thank You to ficho For This Useful Post:
    abdulrauf (6th July, 2022)
  7. #2421
    rob h's Avatar
    May 2011
    Broken device.
    The device does not read the key inserted, in the cgdi itself.
    I tested the coil signal, from the device. It is ok.
    The ir led readers, these have been replaced last year.
    And all worked fine.
    Until today,
    How can i test my device?
    Beside the coil test.
    Greetings Rob
  8. #2422
    Mar 2013
    Europe
  9. The Following 2 Users Say Thank You to bersch8688 For This Useful Post:
    EduardNN (24th June, 2022), rob h (24th June, 2022)
  10. #2423
    rob h's Avatar
    May 2011
    This would indicated that the ir diodes, in the device failed to work.
    I will have a look inside.
    Thank you
  11. #2424
    Check the soldering of the IR LED or replace it.
    For my bad English - scold GOOGLE translator...
    Don`t forget to use
    Thanks button and reputation
  12. The Following User Says Thank You to EduardNN For This Useful Post:
    rob h (26th June, 2022)
  13. #2425
    rob h's Avatar
    May 2011
    I took it appart,
    Under the usb microsope,
    Soldering was fine.
    A small hair, it was ennough to stop it from working.
    Did the test, and it worked like before.
    Thanks guys
  14. #2426
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by rob h View Post
    I took it appart,
    Soldering was fine.
    Thanks guys
    For me the bright sunlight could be problem too. Obviously it's messing with the IR diodes thus i covering the CGDI
  15. #2427
    thank you very much
    Quote Originally Posted by ficho View Post
    9D126B562D8601C0
  16. #2428
    Oct 2018
    egypt
    Thanks to babeh for post 2176 ... added a video for that
    https://www.youtube.com/watch?v=ErGC...el=heshamessam
    wbr.
  17. #2429
    Mar 2019
    Moldova
    Hi!
    Glk 250 cdiX204 (2012). All key lost! I programmed KeylessGo but work as a ordinary key. I used 41 rom, key CGDI Keyless. Does anyone know what the problem is?
  18. #2430
    Mar 2018
    Quote Originally Posted by tankist83 View Post
    Hi!
    What keyless key you are using ?
    The old type keyless key may not work.
    Have you tried lock/unlock door by key ?
    If also not work, check key frequency.
