Page 163 of 178 FirstFirst ... 63113153158159160161162163164165166167168173 ... LastLast
Results 2,431 to 2,445 of 2659
  1. #2431
    Mar 2019
    Moldova
    Quote Originally Posted by babeh View Post
    Какой бесключевой ключ вы используете?
    Бесключевой ключ старого типа может не работать.
    Пробовали запирать/отпирать дверь ключом?
    Если тоже не работает, проверьте частоту ключа.
    how can i know if the key is old or new type?
  2. #2432
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    For this EIS use ROM57 key or china BE.
  3. #2433
    Mar 2019
    Moldova
    Quote Originally Posted by lupu_sandu View Post
    I used china CGDI keylesGo key but available in menu only 41 or 51 rom, i used 41(keylesgo)
  4. #2434
    Mar 2018
    Quote Originally Posted by tankist83 View Post
    The new keyless MB key with ROM41 should work.
    Your EIS is 212 type,
    I have done several W212 keyless.
    check the frequency, 315MHz or 433MHz.
    And what type of keyless key you have brought ?
    As I said there are many keyless MB key.
    And CGDI also has old type which may not work in W204 212.
  5. The Following User Says Thank You to babeh For This Useful Post:
    richard27 (17th May, 2024)
  6. #2435
    please i need erase pass for benz w203 ecu special key- 2B 64 E9 13 C9 97 CD 80
  7. #2436
    please i need pass for w166 ezs to generate key i attached generated data .
  8. #2437
    Oct 2018
    egypt
    I need erase password ... w211 elv ... special key (6a 4f 1c 82 6a 4f 1c 82) .... edit tried different 4 elvs and erase password can't be calculated ... edit solved special key can't be readed directly from elv also you can be sure because its reapeated (Motorola not nec) and could be found from its eis or ecu
    wbr.
  9. #2438
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    Hello, look for information for fare change, esi W204. Esi original broken, I have a used Esi, but I can't find solutions to write original data, in used !
    I have read and created PW, original and used.
    try to write file ori in used, but it gives an error
    Help please
    ..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
  10. #2439
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    Quote Originally Posted by centrohifi View Post
    Help please
    .... SOLVED ....
  11. #2440
    Jan 2016
    Status of key is B56F, what it means?
  12. #2441
    p1et's Avatar
    Oct 2013
    Is it possible to add a key ON CAR (without removing EIS) to W204 when there is no key available? Somebody even tried that?
  13. #2442
    Dec 2015
    Romania
    Yes all key lost with ir ,need 13v and all in obd
  14. The Following 2 Users Say Thank You to ionutdanica For This Useful Post:
    eliet2000 (1st April, 2023), p1et (2nd November, 2022)
  15. #2443
    Mar 2018
    Quote Originally Posted by p1et View Post
    Of course !
    But need to spend an hour to collect data in car if you don't have the AC adapter.
  16. The Following User Says Thank You to babeh For This Useful Post:
  17. #2444
    p1et's Avatar
    Oct 2013
    So procedure is the same, as we do it on table? Connect K-Line wire from OBD to ELV PIN, insert IR adapter and that's all?
    I'm aksing because other tools like avdi, autel, need to connect to some fuse/relay (not sure) under the hood.
  18. #2445
    Dec 2010
    Hi all. need erase pass. thanks
