Page 164 of 178 FirstFirst ... 64114154159160161162163164165166167168169174 ... LastLast
Results 2,446 to 2,460 of 2659
  1. #2446
    Dec 2010
    hi all need erase pass thank you
    Key 1 : D187A0060FB6F70B
    Key 2 : AAAA35F8CC3837F1
    Key 3 : DF8768EB28AD16F2
    Key 4 : D54F9632F3FEEBA8
    Key 5 : EFD0D0CA3D69A11A
    Key 6 : 9DF1AA35B74E974E
    Key 7 : 6C0613CE9A3306E9
    Key 8 : DDB123A22B2A9D62
    Special key: 9326A00250DCA0F7
    Transport Key: C2E901F0EDBA7C5C
    Status : 000F000006060000
  2. #2447
    Quote Originally Posted by bluesky2010 View Post
    try
    42 90 B1 1E 4C 67 C1 9A
    For my bad English - scold GOOGLE translator...
    Don`t forget to use
    Thanks button and reputation
  3. The Following User Says Thank You to EduardNN For This Useful Post:
    bluesky2010 (9th November, 2022)
  4. #2448
    Dec 2010
    Quote Originally Posted by EduardNN View Post
    try
    doesnt work. anyway thank you
  5. #2449
    Dec 2010
    try
    Hello. it works. after many try it worked.
    Thank you very much
  6. #2450
    Mar 2018
    Quote Originally Posted by p1et View Post
    So procedure is the same, as we do it on table? Connect K-Line wire from OBD to ELV PIN, insert IR adapter and that's all?
    I'm aksing because other tools like avdi, autel, need to connect to some fuse/relay (not sure) under the hood.
    All key lost in car, just plug in car OBD, (make sure car battery have enough juice)
    no need to use K-Line, but maybe depends on what benz is it.
    On bench also the same, connect EIS pins to OBD, or if you have EIS cable.
    then just follow instructions on cgdi screen.
    I have been doing that coupe times, without AC adapter need to spend an hour on it to collect data.
    Actually you can just go ahead try it, no harm, except you write something wrong to EIS.
    And no need to worry if all key slots are used.
    just program new key(s) to whatever slot you want, insert key wait a few seconds, start engine.
    I have also been doing all these many times.
  7. The Following User Says Thank You to babeh For This Useful Post:
    richard27 (17th May, 2024)
  8. #2451
    Hi all. Need erase pass. Thank you.
    Special key C0 DB AF ED 1F 5A 75 86
  9. #2452
    Mar 2016
    Can You generate Erase Pass for elv
    My special key - F0 71 13 B7 F0 71 13 B7
  10. #2453
    Mar 2018
    Quote Originally Posted by pandora6 View Post
    Erase pass: 17 16 40 3D 23 5E 65 36
  11. #2454
    Mar 2016
  12. #2455
    This is a old ESL Half Hash as you can see, this should work for you renew:
    8275BA6CEA6DF9DD
    regards ficho
  13. The Following User Says Thank You to ficho For This Useful Post:
    jarekkowalczyk (9th January, 2023)
  14. #2456
    Oct 2018
    egypt
    i have m270 engine ecu ... which is med17.7.2 ... i cann't read with cgdi mb (i want to renew)... but i can read with fc200 (files attached) ... anybody know how to renew with dump files ? ...
    wbr.
  15. #2457
    Mar 2018
    Quote Originally Posted by hesham10 View Post
    That is 2015 CLA180 (Japan),
    it is FBS4, I don't think anything in the market able to renew it.
    Have you ever read the fob key ?
    you will see you even can't make key for it.
    I think you can clone the ecu if you able to write flash and eeprom,
    but you can't renew and program it.
  16. The Following User Says Thank You to babeh For This Useful Post:
    hesham10 (10th January, 2023)
  17. #2458
    Oct 2018
    egypt
    Quote Originally Posted by babeh View Post
    The idea here is that the car is fbs3 ... may i get another ecu ... but also if it's fbs4 its should read (tried earlier on vgs4) ... also original ecu was broken on an accident (no clone option) ...
    wbr.
  18. #2459
    Mar 2018
    Are you sure it is FBS3 ?
  19. #2460
    Oct 2018
    egypt
    I mean the car i want to use the ecu for it ... but donor japan car i don't know exactly ... but i put its vin on epc and see on datacard that its das3 and not sure if that means its fbs3
    wbr.
