Page 165 of 178 FirstFirst ... 65115155160161162163164165166167168169170175 ... LastLast
Results 2,461 to 2,475 of 2659
  1. #2461
    Mar 2018
    Quote Originally Posted by hesham10 View Post
    I mean the car i want to use the ecu for it ... but donor japan car i don't know exactly ... but i put its vin on epc and see on datacard that its das3 and not sure if that means its fbs3
    The donor ECU is DAS4 so technically not able to renew by any tools.
    You can try clone the existing DAS3 ECU (flash & eep) to that donor ECU see if this work.
  2. The Following User Says Thank You to babeh For This Useful Post:
    hesham10 (12th January, 2023)
  3. #2462
    Member agibalov's Avatar
    Jan 2016
    Rostov Don Russia
    Hi.... need Screen CGDI read key ROM 40 our FLAG BYTE
  4. #2463
    Oct 2018
    egypt
    Quote Originally Posted by babeh View Post
    ok how exactly you know that its fbs4 ? ... after 2014 not all cars are fbs4 ... i also know on fbs4 no tool can renew but at least i think should read but not getting erase pass and erase ... mmm i hope i could try the clone option with fc200 but the original ecu was totally damaged on an accident ... anyway thanks for your replies
    wbr.
  5. #2464
    Mar 2018
    Why ask me that !?
    According to your dump your donor ECU is from a Japan 2015 white CLA180, it is Marked DAS4 !
    That's it !
    You don't need to believe me,
    just hook up CAN cable and read the donor ECU in Xentry or Vediamo or whatever and see for yourself !
    You haven't told any info about your fd's car,
    if that is still FBS3 but the ECU is damaged,
    only try clone from the same yr same model ECU,
    or flash with old flash then try SCN coding.
  6. The Following 2 Users Say Thank You to babeh For This Useful Post:
    hesham10 (14th January, 2023), richard27 (17th May, 2024)
  7. #2465
    Oct 2018
    egypt
    Why ask me that !?
    That's it !
    why you say that i don't want to believe you .. no sir .. i appreciate your help and thanks for your replies ... i saw also on dump that it was cla and you are right ... the idea here is that i want to know from vin which should be fbs3 and which is fbs4 (without reading key)
    wbr.
  8. #2466
    Mar 2018
    It is easier if the seller can provide donor VIN to check.
    ECU SW number also can ... but if you know which number is fbs3.
    Feel like the pre-facelift CLA may still fbs3, so try source the old CLA ECU.
    Or if you have chance to read fbs3 CLA ecu, dump into the donor ECU on your hand see if this work.
  9. The Following User Says Thank You to babeh For This Useful Post:
    hesham10 (26th January, 2023)
  10. #2467
    Oct 2018
    egypt
    I need to renew ism ... getting error erase password not found
    wbr.
  11. #2468
    May 2020
    I had an issue with one w204 today. The elv died and needed to be replaced. I read the eis data and pass and after that I connected MK3 emulator. Cgdi would read the emulator and display some data but when I load eis data to write it, the software would crash. After that I only pasted password from eis into the data the mk3 emu already had from factory and only then it wrote successfully without crashing. The elv emu works and car starts, but why does the crash occour? Anyone had simmilar problems?
  12. #2469
    Jul 2019
    Melbourne, Australia
    Quote Originally Posted by turismou View Post
    CGDI doesn't seem to like any emulators not their brand for k-line writing, I tried to personalise a xhorse emulator with CGDI and software also crashed whilst trying to k-line write. Put the same data and the same emulator on my xhorse tool and it wrote no issues, you could probably personalise emulator by Mercedes native OBD/IR method(blank EZS, personalise EZS, write coding, personalise ESL in car, activate EZS) but this will not work if it is a dealer/spare part EZS as they are one time programming.
  13. The Following User Says Thank You to Spiritech For This Useful Post:
    turismou (29th March, 2023)
  14. #2470
    May 2020
    Quote Originally Posted by Spiritech View Post
    Thanks for sharing your experience. I`ve spent time reading earlier posts on this thread. One this is for sure, MK3 emulators can rarely be read correctly. My guess is that CGDI writes at least some data to the emu before crashing. In the end, it only began working when I wrote Pass from EIS to elv. Hope this helps other users in future.
  15. The Following User Says Thank You to turismou For This Useful Post:
    Tagne (9th August, 2023)
  16. #2471
    Mar 2018
    I have been using mk3 emu 2ys ago,
    just write as normal elv, no software crash so far.
  17. The Following User Says Thank You to babeh For This Useful Post:
  18. #2472
    Nov 2019
    Be carefoul with mileage correction w211, cgdi brick instrument cluster :S
  19. #2473
    ttzag's Avatar
    digital-kaos
    w204 ELV is dameged
    remove chip and put to ELV adapter
    read ELV , its disable and need to enable first.
    really its need from 1H to 24H to enable it ??!!
    Actions speak louder than words
  20. #2474
    Jul 2019
    Quote Originally Posted by ttzag View Post
    w204 ELV is dameged
    Yes, all tools take time to reset/enable/remove tp on those chips. Simon Touch also takes several hours. This is one of the reasons emulators are so popular now, remove and unplug faulty unit program emulator job done. I keep a couple refurbished steering locks with reset processors on the shelf as well for customers who still want the steering lock function. Swap over, program, refurbish steering lock(reset NEC, replace motor & relays) when I get home while watching TV.
  21. The Following User Says Thank You to Spiritech For This Useful Post:
    ttzag (1st April, 2023)
  22. #2475
    Mar 2018
    Quote Originally Posted by Kotgacek View Post
    Don't do any mileage correction method other than 'direct write mileage to dash' except you can restore it or restore car to factory status.
    All other methods will write the modded software - software CAN blocker, end up will just screw up everything.
    Actually your dash is not brick,
    just flash correct firmware back it will alive.
    I never seen dash brick except hardware problem.
