Page 171 of 178 FirstFirst ... 71121161166167168169170171172173174175176 ... LastLast
Results 2,551 to 2,565 of 2659
  1. #2551
    Mar 2018
    Quote Originally Posted by wuza View Post
    As far as I can remember some keyless keys need to be activated with password.
    Have you done it? In window key read/ write you have to put password and click activate...
    I am personally not a big fan of keyless key (not only benz, but other brands as well)...
    The proper way is always insert to EIZ the activate key and sync to car.
  2. #2552
    Apr 2022
    Germany
    Quote Originally Posted by babeh View Post
    And when the keyless does not work after key has been inserted in EIS (and activated)? How to activate keyless?
  3. #2553
    Mar 2018
    I haven't experience such problem.
    If you using that key need to activate this way just do it, I've never said you can't do that.
    But it is better if simply activate in normal way.
    BTW what keyless key is it ?
  4. #2554
    Friends, who knows how to change the frequency from 315 to 433.92 MHz on this cgdi keyless go key?
    CGDI mb cannot change
    For my bad English - scold GOOGLE translator...
    Don`t forget to use
    Thanks button and reputation
  5. #2555
    By the way, sometimes the radio channel does not work on w/x164 if the key is registered to the used bus. For it to work, just erase and write EZS again....
    Don`t forget to use
  6. The Following User Says Thank You to EduardNN For This Useful Post:
    p1et (10th April, 2024)
  7. #2556
    Mar 2018
    Quote Originally Posted by EduardNN View Post
    That is not cgdi or vvdi key,
    and I don't think you can program it.
  8. #2557
    Bought as CGDI.
    Programmable/erasable, starts the car when the key is in the lock, no problem.
    Don`t forget to use
  9. The Following User Says Thank You to EduardNN For This Useful Post:
    hesham10 (6th April, 2024)
  10. #2558
    Mar 2018
    Bought as CGDI.
    When did you buy it ?
    Feel like it is the first version of keyless mb key...
  11. #2559
    17.10.2022....
    Don`t forget to use
  12. #2560
    Oct 2018
    egypt
    So proximity is not working? .... any body tried v08 keyless key from cgdi?
    wbr.
  13. #2561
    Mar 2018
    Quote Originally Posted by hesham10 View Post
    V08 is for older models W221 W216 W164 W251.
    What car you are using ?
  14. The Following User Says Thank You to babeh For This Useful Post:
    hesham10 (8th April, 2024)
  15. #2562
    Mar 2018
    17.10.2022....
    At I remember there are at least 3 version of keyless board.
    Probably you have brought the first version of keyless.
    It doesn't support change frequency.
    In the online store I also can't find your version now.
  16. #2563
    Oct 2018
    egypt
    Will try on w211 (older also ends on 2009) ... I know before I buy that it may not be compatible... but I will try and make a video
    wbr.
  17. #2564
    p1et's Avatar
    Oct 2013
    Recently I programmed 2x CGDI keyless keys for W204, it was all keys lost. I rewrite existing position 1 and 2 and I had such situation that remote and push to start did not always work. When put key into ignition it was starting the car everytime. I described that problem here, it must be somewhere on previous or last 2 previus pages.
    So I think you found the solution because you think this will be same problem as yours?
  18. #2565
    honingkoning's Avatar
    Dessert
    Quote Originally Posted by p1et View Post
    Why would you use existing positions.
    I always start from pos 8 and count back.
    If 4/5 positioned are used i make eis virgin and u can re-use all positions.
    Wbr Adam.
  19. The Following User Says Thank You to honingkoning For This Useful Post:
