Page 173 of 178 FirstFirst ... 73123163168169170171172173174175176177178 LastLast
Results 2,581 to 2,595 of 2659
  1. #2581
    honingkoning's Avatar
    Dessert
    Dealer eis maybe ?????
  2. #2582
    Mar 2015
    HI , it don't look
  3. #2583
    Friends, what are your statistics on ezs Dealer EIS?
    For my bad English - scold GOOGLE translator...
    Don`t forget to use
    Thanks button and reputation
  4. #2584
    Jul 2019
    Melbourne, Australia
    I wonder if this works on earlier types with solenoid turn release if you manually release the lock.
  5. #2585
    Quote Originally Posted by Spiritech View Post
    For types with an electromagnetic rotation release mechanism, there is a great crack method that is demonstrated in this video....
    Don`t forget to use
  6. The Following User Says Thank You to EduardNN For This Useful Post:
    antibisic (14th May, 2024)
  7. #2586
    richard27's Avatar
    Aug 2011
    hello I bought it too. Do I need to buy a CDGI AC adapter? It seems like it is lost in some places and gets stuck on the key. Thank you.
    ​information sharing
  8. #2587
    Mar 2018
    Quote Originally Posted by richard27 View Post
    You don't really need the adapter except you need to speedup eis data collection.
  9. The Following User Says Thank You to babeh For This Useful Post:
    richard27 (16th May, 2024)
  10. #2588
    Mar 2018
    Quote Originally Posted by EduardNN View Post
    [video=youtube_share;s6pF8S989fw]https://youtu.be/s6pF8S989fw
    Yes this is the trick to work on dealer eis.
  11. #2589
    richard27's Avatar
    Aug 2011
    hello s 350 smart key How do I do it? Can I do it? Which type of key should I use? I have read and there are versions. I think I learned from you here.
    I think cdgi can make this tool 2012 model car very thanks
  12. #2590
    Mar 2018
    Currently there are two type of keyless cgmb key,
    - W164 W221 W216 08 version for 2005-2010
    - W204 W207 W212 W164 W166 W216 W221 W251 keyless for after 2010
    you should be which you should pick.
  13. The Following User Says Thank You to babeh For This Useful Post:
    richard27 (17th May, 2024)
  14. #2591
    richard27's Avatar
    Aug 2011
    hello masters
    I brought a vvdi keyless go key, coded it to the vehicle, took out the battery and installed it, the red light flashed, after about 40 seconds, the car started, but the keyles goo does not activate. vin : WDD2211831A504620 I tried key 4 and 7 but it didn't work
  15. #2592
    Mar 2018
    hello masters
    what do you mean not activate ?
  16. #2593
    richard27's Avatar
    Aug 2011
    Quote Originally Posted by babeh View Post
    hello It works when I insert the key, it doesn't work when I press the button, sir.
  17. #2594
    Mar 2018
    then this is not 'not activated',
    key status already is "used".
    It is Activated !
    can you lock/unlock door with remote ?
  18. #2595
    richard27's Avatar
    Aug 2011
    It is Activated !
    Yes, the door is locked and unlocked with the remote control, but the vehicle has been tampered with a lot.
    Does this button have a feature or is it like a blank key? battery or a magnet
    I may be asking an unnecessary question please sorry
