Page 177 of 178 FirstFirst ... 77127167172173174175176177178 LastLast
Results 2,641 to 2,655 of 2659
  1. #2641
    richard27's Avatar
    Aug 2011
    Default mercedes w 203
    merhaba mercedes w203 203 545 06 088
    Hello, I bought a contact the other day and when I read that I could use it later, there was nothing here, I added the original file and I found another file from here in case I needed a flash drive and I wrote 1j35d but it still looks like raw, I press wipe the eis but I get an error, how can I get it back to normal?
    ​information sharing
  2. #2642
    Quote Originally Posted by richard27 View Post
    I don't understand anything, but it's very interesting
    Fill the original eeprom with the programmer.
    For my bad English - scold GOOGLE translator...
    Don`t forget to use
    Thanks button and reputation
  3. #2643
    richard27's Avatar
    Aug 2011
    I read this is a second hand ezs this is the screenshot
    then I loaded a dump from another ezs file, there is a single key file, I wrote it
    but it's still the same, I wonder if I'm writing the wrong eprom, orange 5 ori, I read and write like this
  4. #2644
    What you write down is what you see...
    Don`t forget to use
  5. The Following User Says Thank You to EduardNN For This Useful Post:
    richard27 (31st January, 2025)
  6. #2645
    richard27's Avatar
    Aug 2011
    Hello again, what kind of mistake am I making here? I have the eis file and password but I can't write it.
    https://www.youtube.com/watch?v=zIibtcraLFo
  7. #2646
    Nov 2010
    Try to write like normal ELV, not as simulator.
    Simulator read/write works for CGDI simulator.
    Regards, Msmax
  8. The Following User Says Thank You to Msmax For This Useful Post:
    richard27 (7th February, 2025)
  9. #2647
    richard27's Avatar
    Aug 2011
    I'm sorry, I tried everything, I removed ezs and tried it on the desktop, autel also couldn't write, there are 3 emulators, we couldn't write to any of them, anyway, we'll see, maybe ezs is broken, sometimes it works, sometimes the vehicle idles.
    Thank you also for this information Simulator read/write works for CGDI simulator.
  10. #2648
    Apr 2022
    Germany
    Did you had internet connection?
    I did had 1-2 months ago C-Class and I could do it only with internet connection…
    Reading offline was not a problem, but writing only with internet connection…
  11. #2649
    richard27's Avatar
    Aug 2011
    Yes, I definitely have an internet connection. thanks
  12. #2650
    ttzag's Avatar
    digital-kaos
    hello guys
    any one can calculate password please ?
    special key
    3D 19 B2 06 29 B1 2C F3
    i dont know why cant collect data from ezs to uplaod to get pass
    car w204
    Actions speak louder than words
  13. #2651
    Mar 2018
    Quote Originally Posted by ttzag View Post
    hello guys
    special key
    car w204
    You have to collect EIS data to calculate key password.
    Cannot calculate key password with only read EIS data.
  14. #2652
    richard27's Avatar
    Aug 2011
    hello w 906 639 ezs all key lost
    Today I went to get a Mercedes Sprenter lost key and it didn't work. I tried with fast and slow options but it stays while trying to collect data or it says failed at 31% and stays there.
    and I gave up, I brought Autel and it took 15 minutes, it found the password and we added the key I don't understand where the error is. How can I know if the fast adapter is working or not? Adapter Power Fast AC Adapter CDGI MB Tool Goldcar Is there a test simulator for this or something? Thanks.
  15. #2653
    Apr 2022
    Germany
    I personally use CGDI fast adapter only in bench mode.
    I never tried it on the car. It needs external power and I don’t risk it with car’s battery…
    In bench mode works fine.
    What I have experienced with CGDI in AKL on Benz cars is that it takes at least 30 minutes.
    In general it’s needed about 45-60 minutes in AKL mode (direct on the car).
    Cars and laptops batteries have to be in good condition + good internet connection is needed as well.
    If it fails I take out simulation key, clean a little bit the part where the key comes and turn simulation key with in 180 degrees and plug it and start process again…
  16. #2654
    Mar 2018
    Believe that Autel is also using kind of fast mode for data collection that's why it took ~15min,
    and that's why it cost almost 5x than CGDI.
    Autel is more advance for many vehicles,
    while CGMB is more flexible and you can touch the data files.
    Anyway, during all key lost data collection, car ignition actually in off mode,
    then the car will go to sleep mode after a while, OBD will cut power,
    then CGMB will in USB power only, believe that's why you fail at 31%.
    Some car will sleep after 10min, 15?, 30min, 60min, 2h...
    can't tell the exact time, find out on your own.
    So try close and open any door in every 10min to keep the car awake.
    In CGMB normal (slow) mode, data collection take around 60min,
    maybe better remove EIS do it on bench.
  17. The Following User Says Thank You to babeh For This Useful Post:
    richard27 (23rd April, 2025)
  18. #2655
    Is Benz Monster server connection working for you all? I´ve had problems these past few days.
    Currently not connecting at all.
