Page 38 of 178 FirstFirst ... 2833343536373839404142434888138 ... LastLast
Results 556 to 570 of 2659
  1. #556
    Quote Originally Posted by autoTkey View Post
    2 batteries are the keys with battery holder like the first chrome keys.
    1 battery are those who mimic the BGA keys - without battery holder.
    Thank you very much!
  2. #557
    For the most of the keys(except VVDI one) I read this: If Benz key board is broken during key writing, you need to buy another new NEC Chip and it can be written for once only.
    So, which keys are re-writable?
  3. #558
    Feb 2014
    This describes a special situation where you have a problem during key writing or client comes with a broken key and wants repair. And this is probably about original Benz keys only. BE keys are rewritable through IR - no need to remove the NEC in any case.
  4. #559
    You can see that note in this key. I think that it's not a genuine Benz key. What do you think?
  5. #560
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by papalos_ View Post
    This is BE key, can renew anytime.
  6. The Following User Says Thank You to lion0304 For This Useful Post:
    papalos_ (8th May, 2018)
  7. #561
    Dec 2017
    South Africa
    Quote Originally Posted by bersch8688 View Post
    When the other EIS have same Partnumber you can swap MCU 1&2
    The Original Keys from damage EIS will work on the donor EIS
    When you dont have Key's read MCU 1 (Xprog, Orange5,...) and generate Key Dump and write your Key's ;-)
    Just to update, I transferred the 2 MCUs from old to new donor EIS, now the car switches on with both keys, dash come on but no crank. The ESL doesn’t click either way and the lock is stuck in unlock position.
    Could this be the ESL that’s now having a problem. I also noticed the EIS quickly gets very hot once connected with or without key but once the ESL plug is removed, the EIS doesn’t heat up.
    Please advise.
  8. #562
    Mar 2013
    Europe
    Read from the 2 MCU EEPROM!
    Buy second hand EIS and write the EEPROM Data
    Dont SWAP!
    Only read and write!
  9. The Following User Says Thank You to bersch8688 For This Useful Post:
    blesaidoss (10th May, 2018)
  10. #563
    May 2016
    can cgdi renew 7g ?
  11. #564
    Quote Originally Posted by SKYTON View Post
    can cgdi renew 7g ?
    I've asked the same question about 7G and engines ECU renewing many times but nobody answered me.
    the situations are 2:
    1. it just does not work and nobody wants to accept it
    2. Nobody tried it yet(a little impossible...)
  12. The Following User Says Thank You to papalos_ For This Useful Post:
    SKYTON (19th June, 2018)
  13. #565
    Quote Originally Posted by mossa19 View Post
    CGDI MB 2.5.0.0 Update (2018-03-13):
    1. Add ELV repair function, including: enable ELV, virgin ELV (repair damage ELV chip)
    2. Add the function of BE key to save file directly
    3. Add W205, W218,W166 FBS4 EIS type detection
    4. Add save EIS data format flags.
    5. Fixed the problem of part of the ECU,TCU,ISM/DSM/ESM cannot erase
    It's been a long time since the last software version uploaded.
    Are they going to build a newer vesion? What do you think?
  14. #566
    Apr 2016
    pass from bga key works?
  15. #567
    Quote Originally Posted by K1nd3r View Post
    No, it does not read the password from BGA key.
  16. #568
    Feb 2012
    cgdi mb w204 all key lost work fin 63min
  17. The Following 3 Users Say Thank You to inaro For This Useful Post:
    Hayssam1 (17th May, 2018), p1et (17th May, 2018), u.s (20th May, 2018)
  18. #569
    Dec 2017
    South Africa
    Default CGDI Mercedes Benz Programmer
    I’m having issues reading ELS for W204, EIS reads fine as well as the key but ELS doesn’t respond at all. Tried both on obd and bench, yellow K-line was connected. What could be happening, anyone had same problem and possible solutions.
  19. #570
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by inaro View Post
    With power adaptor from VVDI or not?
