Page 51 of 178 FirstFirst ... 41464748495051525354555661101151 ... LastLast
Results 751 to 765 of 2663
  1. #751
    Why not? Key 1 and 2 are used ...
  2. #752
    p1et's Avatar
    Oct 2013
    It will show only if you load dump read by OBD with CGDI. If you read EIS with external programmer and then load dump to CGDI it will not show which positions are used. They should fix it, I reported it like half year ago.
  3. The Following User Says Thank You to p1et For This Useful Post:
    yugo45 (7th September, 2018)
  4. #753
    Apr 2016
    always should gues what position to choose
  5. #754
    p1et's Avatar
    Oct 2013
    If we have working key then we can check on what position is it written, then no problem to just choose one of the others to avoid overwriting working key position. If we have lost keys situation then if we want to keep working keys activated then I ask friend to load dump to SKC and he tell me which positions are free
  6. #755
    the official website has been down since yesterday.
    the password server is still running.
  7. #756
    Aug 2018
    I can open the offical website successfully on my PC.
  8. #757
    yes, site is back
  9. #758
    Jul 2016
    hi... which keys can we use with cgdi? xhorse keys or any chinese keys.
  10. The Following User Says Thank You to canakbas For This Useful Post:
    TMM (28th August, 2018)
  11. #759
    Ecuprog31's Avatar
    Mar 2018
    Chinese key work good
  12. The Following User Says Thank You to Ecuprog31 For This Useful Post:
    canakbas (29th August, 2018)
  13. #760
    Jun 2017
    US
    Just bought one, hopefully this tool and the servers last for a good while. Got a lot to study, hope to not burn up someone's car out there.
    What keys will I need to stock to cover the models this tool can do. Does iyz-3312 fob cover pretty much most of 2002 - 2006? What else should be stocked? Trying to figure out what all will be needed on hand.
  14. #761
    rob h's Avatar
    May 2011
    v2.7.0.0
    w211 2005 keyless go
    1 key present 59
    read eis ok
    collect data, choose key, other keys
    voltage v13.51
    compute pasword,,
    insert key eis ok
    insert key in cgdi
    starting key collection
    after a few minutes, message, is the key loose?
    press ok
    after this message device information failed
    sn: unknown
    it is like the device is disconnected.
    restart program, still getting message device information failed.
    disconnect obd, same
    disconnect usb restart ok
    how can this be, i tried with w7.32 and w7.64
    Run admin, no virus scanner
    internet connection ok.
    voltage 12.5 up to 13.5
    even tried with turned on hazard lights.
    reinstalled software, then updated to 2.7.0.0
    I am now reading it as akl.
    Disconnected elv, connected k-line
    This works, takes about 40min of data reading.
  15. #762
    Mar 2013
    Europe
    v2.7.0.0
    1 key present 59
    read eis ok
    voltage v13.51
    compute pasword,,
    insert key eis ok
    insert key in cgdi
    press ok
    sn: unknown
    I read w221 2008 and Car with Keyless GO and all was fine with collect Data on Car with OBD.
    But at this moment is useless, CGDI can erase NEC from Keyless GO Key but dont write!
    Have 2 Keyless GO Keys here erased but cant write and this moment cant sell too!
  16. The Following 4 Users Say Thank You to bersch8688 For This Useful Post:
    figani (30th August, 2018), IchBins (1st September, 2018), rob h (30th August, 2018), yugo45 (7th September, 2018)
  17. #763
    Hi can cgdi eis/esl virgin with this tool
    Plz information on it thanks
  18. #764
    yes, but i think not all
  19. #765
    Ok can you information what years of car it use and do good job
