Page 53 of 178 FirstFirst ... 343484950515253545556575863103153 ... LastLast
Results 781 to 795 of 2663
  1. #781
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by u.s View Post
    maybe i'm reading this wrong..... but i did AKL job for w204 on table and didn't have to insert the cable key 400 times.
    Probably because you used vvdi power adapter? Am I right?
  2. #782
    Quote Originally Posted by p1et View Post
    No mate, was actually straight forward.
    https://m.youtube.com/watch?v=aI5FeKLMXjA&t=512s
  3. #783
    sorry, that was my mistake, it was not the w204 but a w164.
    only ice, without esl
  4. #784
    Hi!
    I've a CGDI and I bought recently CG pro 9S12 programmer. Reading of HC912 MCU works fine(tried W211 & W169). I also tried to read W203 EZS HC908 on board but it seems to be not working. Has anyone tried to read onboard W203 or W639(HC908 based)?
    The CG pro 9S12 software informs me that the license will expire in 23 days. So what is up after the expiration? Does anybody know?
    Best Regards
  5. #785
    Quote Originally Posted by lion0304 View Post
    Just check out my CGDI after extended. I also have CG100
    So far, so gooddddddd. HAPPY END for all. Now just enjoy again this tool.
    Hi lion!
    I've a CGDI prog MB and a CG pro 9s12 device. Is possible to "combine" them to gain tokens and features? For example, how could I enable the function on the picture? I asked the seller I bought both devices and he told me it's not possible.
    Best Regards
  6. #786
    rob h's Avatar
    May 2011
    If you have CG100 PROG III Airbag Restore Devices and CGDI Prog BMW MSV80, pls pass us serial number to bundle them together, you will have two more tokens, which means 4 free tokens per day.
    Out of 4 devices, you choose the wrong ones twice!
  7. #787
    Quote Originally Posted by rob h View Post
    Out of 4 devices, you choosing the wrong ones twice!
    Why twice mate? I've got 2 devices. The first one is CGDI prog MB and the second a CG pro 9s12 device.
    Based on 2.6.0.0 CGDI update (http://www.obdii365.com/wholesale/cg...rogrammer.html) you can read a few lines later:
    "This function needs to be opened separately, such as holding the other equipment of our company (CGDI BMW, CG-Pro), will automatically open"
    If you click on CG-Pro, a page that indicates on "CG Pro 9S12 Freescale Programmer Next Generation of CG-100 CG100 Support CAS4/CAS4+ All Key Lost" will be load.
    Best Regards
  8. #788
    rob h's Avatar
    May 2011
    Free tokens no, mileage adjustement free, yes.
    If you have BMW, and prog.
    Not MB, and prog.
  9. The Following User Says Thank You to rob h For This Useful Post:
    papalos_ (17th September, 2018)
  10. #789
    yugo45's Avatar
    Quote Originally Posted by yugo45 View Post
    Anyone try to renew ME9.7 , does it work ?
    Please if anyone has any feed back post it.
    Can someone answer this , please?????
  11. #790
    Jan 2016
    Server is down?
    Closed.
    Server is UP-)))))))
  12. #791
    Yerevan
    Yes its work for me fine
  13. The Following 2 Users Say Thank You to davo2 For This Useful Post:
    Nymike (18th September, 2018), yugo45 (18th September, 2018)
  14. #792
    May 2015
    Renew 9.7 worked for me too, need to try it few times though. Also I did it on the bench. So far renewed mb edc17c01, c10, c46 and mevd172 from c class. All worked.
    Sent from my SM-G950U using Tapatalk
  15. The Following 2 Users Say Thank You to Nymike For This Useful Post:
    doctore (20th September, 2018), yugo45 (18th September, 2018)
  16. #793
    rob h's Avatar
    May 2011
    I ve tested renew edc16 w906 and a sim4le w203.
    Works good.
    Using the vvdi ecu cable set
  17. The Following 2 Users Say Thank You to rob h For This Useful Post:
  18. #794
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    hi... get my cgdi and works fine until now...
    I read a lot of the their products, the most here and something also on their own company homepage...
    When you take PLAN A:
    Plan A: Two free tokens each day valid for 180 days. When license gets expired, please pay to http:....
    After you pay for it, can calculate online two times free each day again. You can calculate 60 times one month.
    Itīs clear and understanable....
    When you choose Plan B:
    Plan B: One free token each day all the time. And it won't get expired anymore. If you want more tokens, one token will cost 4.6usd.
    Please pay for http:... You can calcualte 4 times at most each day.
    Than comes a sentence....:
    Besides if you have cgdi-bmw-auto-key-programmer or cg100-prog-iii-auto-computer-programmer
    pls pass us serial number to bundle them together, you can get one free token then.
    when you own mercedes and bmw.... so I understand it... you will get one more each day...
    in the case that you have plan A you will have each day three tokens (2 with plan A and and more.. = 3)
    in the case that you have plan B you will have each day two tokens (1 with plan B and one more... = 2)
    itīs my side of the story...
    they (Anna and Lisa)... write that youīll only get one token more when you have PLAN A...
    I asked where does it stay...
    Answer from them: ... I missunderstand it all....
    Maybe my englisch is bad...
    What are your experience with them...?
  19. The Following User Says Thank You to figani For This Useful Post:
    p1et (20th September, 2018)
  20. #795
    p1et's Avatar
    Oct 2013
    I have 1 token / day from beginning and tool got it's expire time. After 180 days I needed to re-activate for 70 usd for next half year and I stil have 1 token per day. So I'm being fcked
