Page 56 of 178 FirstFirst ... 646515253545556575859606166106156 ... LastLast
Results 826 to 840 of 2659
  1. #826
    I am using vvdi cables and they are working, unless the unit I had has a hardware failure but I already tried the k line for reading the esl of the 204 and it already read it . Could it be the IR key?????
  2. #827
    Quote Originally Posted by K1nd3r View Post
    this tool can not make keys for w202 w210 w208, with existing Motorola based key can not extract password, with ezs eeprom calculated keys not working
    This is not a problem. Read the eis over obd. save the data. then read moto key with programmer, for example i use carprog. load the key dump into cgdi, there you will see the password. add pass to eis dump. I think they get the rest alone.
  3. The Following 2 Users Say Thank You to IchBins For This Useful Post:
    figani (30th September, 2018), rob h (30th September, 2018)
  4. #828
    Jun 2017
    US
    If a 2000 s500 or any other Benz has the old all black fob will China chrome fobs work as well?
  5. #829
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by darknezz19 View Post
    Yes, will work.
  6. The Following 3 Users Say Thank You to p1et For This Useful Post:
    darknezz19 (30th September, 2018), Ecuprog31 (1st October, 2018), klesk1986 (1st October, 2018)
  7. #830
    rob h's Avatar
    May 2011
    Still no solution for W906 dump to key calculator.
    I tried to calculated these dumps, using V2.7.2.0
    Not working,
    http://www.digital-kaos.co.uk/forums...06#post3322259
  8. #831
    Apr 2016
    tested on w906 2006-2012, works
  9. #832
    rob h's Avatar
    May 2011
    Yes, the old ones work. I like it to work on 2012-2015, like vvdi mb.
  10. The Following User Says Thank You to rob h For This Useful Post:
    yugo45 (2nd October, 2018)
  11. #833
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by grzyb26 View Post
    CG-MB BenzMonster V2.7.2.0
    (2018.09.20)
    1. Fixed the problem that read EIS failed when 209/211 collection with key.
    2. Fixed the problom that 209 sync ELV and 169 write ELV display is not clear.
    3. Fixed the problom that the K-line EIS is enabled successfully, but the display fails.
    http://www.cg100iii.com/benz/BenzMonster_Setup.exe
    Someone have other link? This one doesn't work and I cannot find a working one
    EDIT. OK, nevermind. I couldnt open the software but I changed USB cable and now is ok, im downloading through device menu
  12. #834
    Jun 2017
    US
    2007 c230 can it handle all keys lost if we do it on the bench? What all components have to be removed from the car?
  13. #835
    raimi.s's Avatar
    Garage
    Tested on Sprinter 2016 works good. Just before load file need delete couple lines with winhex
  14. The Following 2 Users Say Thank You to raimi.s For This Useful Post:
    klesk1986 (9th October, 2018), yugo45 (9th October, 2018)
  15. #836
    ray-ray's Avatar
    What lines did you repair? I’m looking into these tool, so every info. Is important.
  16. #837
    grzyb26's Avatar
    Jan 2012
    w212 2010 all key lost ok
  17. The Following User Says Thank You to grzyb26 For This Useful Post:
    p1et (10th October, 2018)
  18. #838
    p1et's Avatar
    Oct 2013
    I have the tool for almost a year now so I was one of those person who invested this tool without reading many(positive) real customer opinions and later on I gave some such positive opinions here but now I'm being treated worse than new customer who want to buy this tool, this is ridicolous.
    Now if you want to buy this tool you can choose a plan: 2 tokens / day and activation for 180 days - re activate 80usd next half year. Or you can choose other plan which is: 1 token / day and no time expire.
    As an old customer I cannot change to 1 token / day, I thought they are joking but unfortunately not...
    I'm pissed.
  19. #839
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Quote Originally Posted by p1et View Post
    I'm pissed.
    You can always sell it, and buy a new one As an old customer
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  20. The Following User Says Thank You to doctore For This Useful Post:
  21. #840
    p1et's Avatar
    Oct 2013
    Actually, that's not a bad idea
