Page 59 of 178 FirstFirst ... 949545556575859606162636469109159 ... LastLast
Results 871 to 885 of 2659
  1. #871
    the answers i know but i ask all my friend about go some new
  2. #872
    scotland clydebank
    i year ago forgotten thank you .
  3. #873
    Jun 2017
    US
    Tried to repair customers broke fob but NEC chip is bad. Can we add new key with CGDI if they bring me EIS module? That's all we need if doing it on the bench right? 2007 C230 Sport.
  4. #874
    Mar 2013
    Europe
    Yes it work ;-)
  5. The Following User Says Thank You to bersch8688 For This Useful Post:
    darknezz19 (16th October, 2018)
  6. #875
    Jun 2017
    US
    How would it work? Is there a eeprom to take off the EIS and solder it to the adapter board or does it interface another way? Thank you.
    Edit, I see how it interfaces, but don't know the pinout. I'll report back with the eis model once it's dropped off.
  7. #876
    Jun 2017
    US
    Looks like it's an EIS 209 and CGDI lists it able to do all keys lost. Will it do it through OBD or must be on bench?
    https://imgur.com/a/WKP5emT
  8. #877
    is server down?????
  9. #878
    magneto21's Avatar
    Jul 2016
    looks like, I got the same thing
    I have to use it avdi.
    It always good to have backup
    regards
    “The capacity to learn is a gift; The ability to learn is a skill; The willingness to learn is a choice.”
  10. #879
    can I repair with this tool broken of china NEC key programmer remote bytes in OEM nec keys?
  11. #880
    Hello , does anyone knows if server is back again
  12. #881
    Jun 2017
    US
    Yes it's back up, for now.
  13. The Following User Says Thank You to darknezz19 For This Useful Post:
    tech111 (24th October, 2018)
  14. #882
    amrif's Avatar
    EU
    I need pinout for edc16 W211 cr3.43.
    There is Kline on 31, CAN 54,53, ground 2, +30 5, 19 and doesn't work. Why?! (I try with and without 120ohm)
    ECU working fine on car. \\solved problem with cgdi supply
    If I helped you please remember to give thanks and rep. A little thanks goes a long way
  15. #883
    Jul 2015
    Hello, i bought MB CGDI recent. I choose plan B, 1 token free each day lifetime ( however i see on my software CGDI MB, active day is 365, i do know what is reason). i want addtionally to buy a BMW CGDI and contact your saler. The saler tell me that if i have new BMW CGDI, i will only receive 1 token free 1 time equal only 4$, it mean that i still have 1 token free each day. And they will bind MB CGDI and BMW CGDI together, that will add more function as read/write Mercedes Gateway. It mean that, people have only MB CGDI, do not have BMW CGDI and CG100, can not read/write Mercedes gateway. Can anybody tell me it is true or false. Thanks
  16. #884
    I have cgdi mb with plan b I tried to read w221 dashboard and gateway it gave contact seller I thought they are not supported yet.
    Maybe someone here can explain also, or is there any representative for them on this forum
  17. #885
    Jun 2017
    US
    Tried to do a W209 AKL and read EIS through OBD fine. Went to collect key data and when it asks to disconnect ELV and connect clip to Kline, then insert simulation key, it would fail every time. Software said 12.01v on the car. Tried many times.
    They only way it would read was by leaving the ELV plug connected and then connecting to Kline. It read data for about an hour and 45 minutes, saved file but got an error when trying to upload for calculation.
    What am I doing wrong? Do I need a gateway for 209 or was it possibly a CAN system? How can I tell if it's CAN?
