Page 78 of 178 FirstFirst ... 2868737475767778798081828388128 ... LastLast
Results 1,156 to 1,170 of 2659
  1. #1156
    Yerevan
    The device will not work with the old software.
  2. #1157
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    once updated software and then also updated FW in tool...
    there is no way back, with only installing older software...
    will not work...
  3. #1158
    Nov 2015
    this is a problem with cgdi mb!!!
    We have to find a solution.....
    They forced us to upgrade!! and there is no return....
    Best regards to all!
  4. #1159
    I am trying to erase W204 ELV and I am having message : {Sorry Erase password not found}
    please can someone calculate the erase password . This is the special key : E6 E3 54 EF DB 76 FC 81
    THANKS
  5. #1160
    Aug 2010
    Quote Originally Posted by abdulrauf View Post
    THANKS
    Here is your erase password:
    Jonny
  6. The Following 3 Users Say Thank You to jonny r For This Useful Post:
    abdulrauf (9th March, 2019), daxxer (9th March, 2019), lion0304 (9th March, 2019)
  7. #1161
    Quote Originally Posted by jonny r View Post
    Jonny
    thank you very much the pass work ok. thanks
  8. The Following User Says Thank You to abdulrauf For This Useful Post:
    jonny r (9th March, 2019)
  9. #1162
    figani's Avatar
    Feb 2018
    Quote Originally Posted by hcaa View Post
    When you get the window to update your software... Just press later... And you don't have to press update software... You can do it later or even never... It's up to you...
    But in the most cases they have something new in their updates so it's interesting to get it...
    But I understand what you try to say with your words...
  10. #1163
    p1et's Avatar
    Oct 2013
    Guys is there a way to obtain 'enable key password'? I disabled 1 of my car keys and now I want to enable it again but CGDI cannot calculate it. At first it displayed enable password is '0' and asked me if I want to continue. I don't know what that 0 means but if I continue it fails to calculate. I never done this disable/enable function before.
  11. #1164
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by p1et View Post
    If i remember good, when we disable key, only dealer can active it.
  12. The Following User Says Thank You to lion0304 For This Useful Post:
    p1et (10th March, 2019)
  13. #1165
    Quote Originally Posted by lion0304 View Post
    You can enable the key yourself, but you need the key password to calculate the enable password.
  14. #1166
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by IchBins View Post
    thats interesting, can you be more specific?
    thx
  15. #1167
    I have a Vito W639. The owner has bought a new key from the Mercedes dealer. But the key did not work.
    Problem was that the new key (# 3) was disabled in eis.
    Proceed as follows: First, we need the key password from the EIS. So collect data ... etc. If we have this, we will click on "get enable password". Of course we need an online connection.
    When the enable password has been calculated, click enable, select the key to activate, and click OK. You need the IR simulation key.
  16. The Following 3 Users Say Thank You to IchBins For This Useful Post:
    EduardNN (10th March, 2019), figani (10th March, 2019), p1et (10th March, 2019)
  17. #1168
    Mar 2015
    UA
    If the key is locked by Star, then according to this method, you unlock the key only in EZS. And in the ECL and motor ECU the key will remain locked.
    I can not understand the specifics of the device. To calculate the dealer password and calculate the key password, if you lose it completely, do you need to use a token and an online connection? How much does a token cost and what is this 180 days that is remembered in sellers' prices?
  18. #1169
    p1et's Avatar
    Oct 2013
    Ok so I think I understand why it didn't worked for me because at the main screen I had just EIS data read without key password. I have password so I will plug again, read EIS and paste known key password and then try calculate enable password. Will let you know the results. Thanks
    But I don't understand why we can disable any key without having any password if we need password to enable them again. Would be better and more convienient if we need password to disable also.
  19. #1170
    Quote Originally Posted by MVVL View Post
    That is not right. I did it myself and it works.
    For the CGDI, to calculate the passwords you need an online connection, since the calculation runs on an external server.
    The 180 days. this is one of the possible licensing models from CGDI. You can every day calc two free passwords for 180 days. After that, you have to pay 60 usd to activate the device for another 180 days. You can also buy token individually, they cost 4 usd.
  20. The Following User Says Thank You to IchBins For This Useful Post:
    yugo45 (27th March, 2019)
