cgdi does not read nec 567897081. chip nec 071 and 041 read well. Maybe a new update is to blame?
Some users wrote, that they have also problems after update with 7g unit renewing...
last update is not good not work data collection in some w164 ezs
barho67 (17th May, 2019)
HI, can its make key for w906 2007?
barho67 (19th May, 2019)
please i need erase password to renew TCU VGS TRANSMISSION CONTROL UNIT
Special Key - AD02FA15173092EB
Here is your Erase pass:
Jonny
thanks it work ok
jonny r (25th May, 2019)
Hello.
Anyone can help me with erase password for this ecu?
CGDI cannot find it. Thanks
Special key: 23 45 E3 C2 86 E3 A8 38
Here is your Erase Pass:
Jonny
kristikapa (24th May, 2019), yugo45 (30th May, 2019)
it's just me or something went wrong with the latest update?
Same key, same car w211
Usb connected, 12v connected read key via infra ok
usb connected, obd connected read key via infra ok
Usb connected, read eis ok, collect data, 11.94V detected, 1th step ok, second step read: key via infra. No key or loose key or something similar
after that usb still connected, obd still connected, read key, "pls connect 12v" (??????) okay 12v connected too, nothing, again "pls connect 12v"
Eveything disconnected sw restarted, again:
Key reading working fine.
Same like before except 12v connected too direct from the car battery with the same result.
Basically the key reading/detecting working fine except under data collecting
any idea?
thx
Can CGDI erase EIS mileage in cars like W166 , W204, W212, W246?
