Page 90 of 178 FirstFirst ... 40808586878889909192939495100140 ... LastLast
Results 1,336 to 1,350 of 2659
  1. #1336
    newone's Avatar
    Oct 2016
    Hello,i would like to know when fbs4 first appera and if there is a list with cars that use it
    thanks in advance
  2. #1337
    Hello.
    Anyone can help me with erase password for elv W204?
    CGDI cannot find it. Thanks
    Special key: A4 DB BE A7 4F 15 23 8F
  3. #1338
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by jodge View Post
    it's just me or something went wrong with the latest update?
    Same key, same car w211
    Usb connected, 12v connected read key via infra ok
    usb connected, obd connected read key via infra ok
    Usb connected, read eis ok, collect data, 11.94V detected, 1th step ok, second step read: key via infra. No key or loose key or something similar
    after that usb still connected, obd still connected, read key, "pls connect 12v" (??????) okay 12v connected too, nothing, again "pls connect 12v"
    Eveything disconnected sw restarted, again:
    Key reading working fine.
    Same like before except 12v connected too direct from the car battery with the same result.
    Basically the key reading/detecting working fine except under data collecting
    any idea?
    thx
    Got it. It was a really early keyless key and it seems CGDI not handling properly. Unfortunately the result is strange behavior not clear error messages.
  4. #1339
    Oct 2017
    I programmed my first ever Mercedes Benz Key with this tool and for someone that doesn't have any experience Mercedes just bunch of reading here on the forum it was very easy and thanks to the videos and the info Ive found here. I think I undersold the job at $300 it was a w164 2006 I had to remove zgw myself too since I didn't have emulator and it was a pia I also supplied the key and obviously went to the location of the vehicle. So I'm wondering if $300 was too cheap for this job.
    What do you guys think?
    Sent from my SM-N950U using Tapatalk
  5. #1340
    Quote Originally Posted by pandora6 View Post
    Hello.
    Here is your request
  6. The Following 2 Users Say Thank You to ficho For This Useful Post:
    daxxer (22nd June, 2019), jonny r (22nd June, 2019)
  7. #1341
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by esx503 View Post
    We everyone working in different regions, have different competitors, different working conditions, different money invested in the tools so we cannot speak about prices on forum if this or this price is OK. You did the job and that's most important. If you feel 300usd is a little bit less than you'd like to , then next time you will raise your price. For the first time I think most of us set a little bit lower price for such things as you don't have experience. Everyone learned at some point and what is most important for customer? Of course price. Don't be too cheap to your competitors, don't be overpriced and everyone will be happy.
  8. The Following User Says Thank You to p1et For This Useful Post:
    k1mlock (4th October, 2019)
  9. #1342
    please i need erase pass for W204 steering lock,
    special key- 2D96ABAB31CF4864 .
    Thanks .
  10. #1343
    Quote Originally Posted by abdulrauf View Post
    Thanks .
    That is a bad special key: someone also has requested same special key before:
    https://www.digital-kaos.co.uk/forum...=1#post2738481
    regards
  11. The Following 2 Users Say Thank You to ficho For This Useful Post:
    daxxer (22nd June, 2019), jonny r (23rd June, 2019)
  12. #1344
    Oct 2017
    Quote Originally Posted by p1et View Post
    Yea thats the reason why I feel I charged the customer cheap because I had no experience. Thanks for your input.
  13. #1345
    May 2017
    España
    300€ only for do a key?
    Enviado desde mi iPhone utilizando Tapatalk
  14. The Following User Says Thank You to hrmotorsport For This Useful Post:
    esx503 (23rd June, 2019)
  15. #1346
    p1et's Avatar
    Oct 2013
    I assume it was all keys lost.
  16. #1347
    May 2017
    España
    If includes open car and cut code its ok.
  17. #1348
    Oct 2017
    Quote Originally Posted by hrmotorsport View Post
    $300 he had a key that stopped working and I was able to use that key to retrieve the password. it was very fast, I was surprised at first I thought I must be doing something wrong because this is just way too fast. I did all the work on removing the modules and diagnosing the issue. I have another customer with a 2006 c320 with ignition problems I'm charging him $450 to do the job I think I'm satisfied with what I'm getting since these are wholesale customers and always pushing work my way. I can't be too greedy.
    BTW I'm stuck with this ezs cloning. on the ezs it's a w209 off the 2006 c230 I just came back from the junkyard to see if I could find an ezs with the zgw off the same car but I could not find the zgw on any of the 5 cars I checked. Is there an zgw on these cars or did I just look in the wrong spot? if there isn't one how can I read this on bench without zgw?
  18. #1349
    Nov 2015
    Hi to you all!!!
    PLEASE i need erase password for EIS 1695451708
    My CGMB gives ...."Sorry erase password not found!"
    my Special key is...
    9675B877EDE27433
    key pass...
    2D52C805A1F9F4BA
    Thank you
    Kind Regards,
    Dimitris
  19. #1350
    Aug 2010
    Quote Originally Posted by hcaa View Post
    Hi to you all!!!
    9675B877EDE27433
    key pass...
    2D52C805A1F9F4BA
    Thank you
    Kind Regards,
    Dimitris
    Here is your Erase Pass:
    Jonny
  20. The Following 3 Users Say Thank You to jonny r For This Useful Post:
    ficho (24th June, 2019), H.Wessel (24th June, 2019), hcaa (24th June, 2019)
