Page 52 of 178 FirstFirst ... 242474849505152535455565762102152 ... LastLast
Results 766 to 780 of 2663
  1. #766
    spiridonas's Avatar
    hi guys please I'm thinking to order one tool for mb ezs, eis,elv, key,
    repair service. What do you suggest me?
    This is tool is good for this job ? and from by whom reliable seller ?
    Many thanks in advance
  2. #767
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by spiridonas View Post
    For starting this is good for money, when you have more, buy another.
    You can buy from every place, ali or direct from their website: http://www.cg100procar.com/
  3. The Following User Says Thank You to lion0304 For This Useful Post:
    spiridonas (3rd September, 2018)
  4. #768
    DK Veteran elmassioui's Avatar
    Dec 2010
    Quote Originally Posted by IchBins View Post
    Why not? Key 1 and 2 are used ...
    hi
    by obd cant read position of key
  5. #769
    yugo45's Avatar
    Apr 2010
    Quote Originally Posted by p1et View Post
    If we have working key then we can check on what position is it written, then no problem to just choose one of the others to avoid overwriting working key position. If we have lost keys situation then if we want to keep working keys activated then I ask friend to load dump to SKC and he tell me which positions are free
    If you install SKC , you can load dump and see everything, key position, SSID and etc , only thing you can not calculate key with out dongle .
  6. The Following User Says Thank You to yugo45 For This Useful Post:
    p1et (7th September, 2018)
  7. #770
    Apr 2016
    you also can find all direct in dump, what for all this soft
  8. #771
    Jun 2017
    US
    Bought one of those chrome China IR keys with the black plastic circle in the middle. It came with a Benz crest separate. DO we open the fob and remove that black plastic circle to open an area for the Benz crest?
  9. #772
    rob h's Avatar
    May 2011
    Just take a sharp box cutter, and pop it out.
    Then place the logo.
    It only fits correct in 1 of the 3 posible positions.
    So have a good look at the back of the chrome logo, before you ruin it.
    Quote Originally Posted by darknezz19 View Post
  10. The Following 2 Users Say Thank You to rob h For This Useful Post:
    darknezz19 (8th September, 2018), yugo45 (8th September, 2018)
  11. #773
    Jul 2010
    Quote Originally Posted by elmassioui View Post
    hi
    why not? it shows the used keys, as well as which was used as last and as penultimate
  12. #774
    Jul 2010
    just seen, version 2.7.1.0 is available
    CG-MB BenzMonster V2.7.1.0 NEW
    (2018.09.08)
    1.Added function: read FBS4 gearbox basic information
    2.Fixed the problom that partial device upload data validation failed
  13. #775
    koolstuff's Avatar
    Nov 2015
    Dakar (Senegal)
    Hi there i have a little problem with CGDI Benz, i tried to collect data for all keys lost but when it ask to insert the IR key it says failed to get data, i have made some keys already and device is actived and registered. i have used W212 EIS cable and supply 12v i have tried many times but it always says failed to get data. VVDI benz has collected already the data but i dont have 2 tokens left for AKL.
    Any help is really appreciated
    Last edited by koolstuff; 14th September, 2018 at 02:03 AM. Reason: upload picture
  14. #776
    Jul 2010
    Have you ever used the simulation key from cgdi? maybe he is defective. I have made keys for w204, you have to insert and remove the cable key 400 x
    Is the EIS OK, can it read keys? Try another eis, w211 is good. it does not take that long.
  15. #777
    p1et's Avatar
    Oct 2013
    All key lost procedure in car?
  16. #778
    yugo45's Avatar
    Apr 2010
    Anyone try to renew ME9.7 , does it work ?
    Please if anyone has any feed back post it.
  17. #779
    Jul 2010
    no, on table
  18. #780
    Dec 2008
    maybe i'm reading this wrong..... but i did AKL job for w204 on table and didn't have to insert the cable key 400 times.
