Page 79 of 178 FirstFirst ... 2969747576777879808182838489129 ... LastLast
Results 1,171 to 1,185 of 2659
  1. #1171
    Mar 2015
    UA
    To calculate the password to reset the blocks, you also need a token and an online connection?
  2. #1172
    Mar 2015
    UA
    So who can explain - what does the manufacturer stipulate for 180 days? What passwords are we talking about? Is the key password or dealer password from the lock on the NEC processor or on the Motorola processor? What is it about?
  3. #1173
    May 2010
    Hi all
    I have just bought A CGDI unit to program replacement keys etc.
    I see BE keys are good for most mb's 2000 - 2015. Which keys work for older das3? Like w210 etc? Can anybody explain or help me with a good place to buy them?
    Also, I assume I can program an older original key to the eis with CGDI, or do I need to re write key?
    What happens with keyless go keys?
  4. #1174
    newone's Avatar
    Oct 2016
    Hello friends,can someone explain the proccedure to dissable a key because it was stolen,thanks in advance.
  5. #1175
    rob h's Avatar
    May 2011
    You could make a new key, in that same place. Old key stops working!
    Quote Originally Posted by newone View Post
  6. The Following 2 Users Say Thank You to rob h For This Useful Post:
    MARIKO (13th March, 2019), newone (13th March, 2019)
  7. #1176
    May 2010
    Or you can remove old key from key track with STAR/Xentry
  8. The Following User Says Thank You to 320cdiman For This Useful Post:
  9. #1177
    Oct 2014
    HI SOLUTION SUR ELV W204 MESSAGE CHECK ELV---- ELV IS DAMAGED
  10. #1178
    DK Veteran elmassioui's Avatar
    Dec 2010
    Helllo. You need to follow the order of operation.
    Envoyé de mon LLD-L31 en utilisant Tapatalk
  11. #1179
    Dec 2010
    Quote Originally Posted by elmassioui View Post
    Disolder the chip from board first
  12. #1180
    Oct 2014
    MUST DO 3 ETAP
  13. #1181
    Dec 2010
    Yes. On enable part may take 30 mn if chip not full damaged.
  14. #1182
    Oct 2014
    AFTER 3 HOURS
  15. #1183
    mislav88's Avatar
    Mar 2011
    is virgin step necessary? or chip can be resoldered back to elv and adapted from elv menu?
  16. #1184
    droidwayne65's Avatar
    Aug 2015
    North America
    Quote Originally Posted by jonny r View Post
    Hello,
    Here is your erase password:
    Attachment 602390
    Regards
    Jonny
    Interesting, useful-looking app. Is it available for distribution?
    Never mind. As usual, I'm sooo behind the times.
    <---- Coin of the Realm.
  17. #1185
    EARTH
    Default key pass
    I need cgmb key pass.
    I need to sync elv.
    Uobd2 is slowing down with tokens.
    Some help?
