Results 1 to 15 of 2663
Hybrid View
    Mar 2018
    Quote Originally Posted by papalos_ View Post
    I've only done tests on the bench. I haven't tried it in on vehicle. "Check EIS status" shows only mechanical status as ticked during key rotation, car status remains blank.
    If you have EIS/ELV test cable or testing platform you can test it on bench.
    You are working on bench you should also able to test it on bench, do you ?
    Mar 2010
    Quote Originally Posted by babeh View Post
    Yes I have cable set and I'm testing EZS-ELV-Key on bench. I don't understand the question.
    Mar 2018
    If you have other ELV or maybe the original working ELV then you can confirm your test cable wired and is working properly.
    When checking EIS status and if you not getting 15R tick,
    means either the ELV not programmed or not working or not connected properly or other problems.
    Maybe I will get that mini ELV later to see how is it.
  4. The Following User Says Thank You to babeh For This Useful Post:
    papalos_ (7th April, 2021)
