Page 115 of 172 FirstFirst ... 1565105110111112113114115116117118119120125165 ... LastLast
Results 1,711 to 1,725 of 2578
  1. #1711
    mapexo's Avatar
    Mar 2017
    Germany
    Plug Is okkk
  2. #1712
    Dec 2009
    scotland clydebank
    need to use this device to add a key tomorrow my garage mechanic has just bought one and has a few mercedes keys to do as anybody a idiot guide for adding key
    seen cgdi
    instructions for adding key the look misleading just on collect data and upload data is there any failsafe incase you make mistake thank you as never worked on
    mercedes before .
  3. #1713
    Feb 2016
    Collect data->save file->load it->query result->copy pass->read eis data->in reading eis window paste your pass and save eis data->generate keys-> write key->be happy.
    Отправлено с моего Redmi 3S через Tapatalk
  4. #1714
    Dec 2009
    scotland clydebank
    updated cgdi to latest software trying to read data on a w215 220 mercedes says read error any help please also manually selected chassis .
  5. #1715
    Dec 2009
    scotland clydebank
    Just made spare key car starts with both keys just been told steering lock not
    Longer working can somebody explain the
    Key generation file
    I was going trough some
    Cgdi mb pages and the generation
    Of keys very confusing
    Does anybody knows why
    Steering no longer locks thank you this is my
    Mechanic car w210 mercedes
  6. #1716
    super jumbe's Avatar
    Dec 2008
    Livingstone
    The only trusted company came with the idea that you don’t need to solder wires to read dump, you put the board in the reader on you go and read the dump and this tool 100% works better then AVDI arbrites.
  7. #1717
    Dec 2016
    Quote Originally Posted by godfathertre View Post
    Key generation file
    On W210 you can not even turn the key in the EIS if steering lock does not communicate with ignition switch. You would not be able to start the car for sure. I guess steering lock mechanism has failed.
  8. #1718
    Dec 2016
    I have successfully programmed elv simulator on W204, password calculation took less than 1 min. Did everything on the car through obd connector.
  9. The Following 2 Users Say Thank You to 111arm For This Useful Post:
    nenadgorgi (8th December, 2019), taxo1965 (8th December, 2019)
  10. #1719
    Dec 2009
    scotland clydebank
    The steering lock was working fine on the with old key before adding another key
    The owner my mechanic says
    The lock is in the unlocked position all the
    Time does not lock once both keys removed
    And the vehicle starts and run with both
    Keys.
  11. #1720
    please help me with erase pass for VGS reset . this is the special key - ED A2 49 9B 1A 46 C4 84 .
  12. #1721
    Aug 2010
    Quote Originally Posted by abdulrauf View Post
    Hello,
    Here is your Erase Pass:
    Regards
    Jonny
  13. The Following 4 Users Say Thank You to jonny r For This Useful Post:
    abdulrauf (10th December, 2019), daxxer (11th December, 2019), ficho (11th December, 2019), taxo1965 (12th December, 2019)
  14. #1722
    Feb 2012
    Hello I need help. Can I replace EIS 2035450308 in MB C class W203 2003 YEAR with second hand one. I have original working key and I can read EIS on table. I heared that CGDI only can erase EIS 2035450308 . Can I replace EIS 2035450308 with 2035450508. Thanks in advance.
  15. #1723
    Feb 2012
    Nobody can help? Please.
    Quote Originally Posted by alkazav View Post
  16. #1724
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    if it recognize as dealer eis, cgdi is not able to write it again after erasing...
    if normal eis, then itīs not a problem...
  17. The Following User Says Thank You to figani For This Useful Post:
    alkazav (11th December, 2019)
  18. #1725
    Feb 2012
    please help me with erase pass for w203 special key - B3 A3 A6 2D 5A 5F DA 23
