hi all. does anyone have this adapter? I would like to know the pinout. Thanks
Friends, no one has this adapter?
please i need erase pass for w203 ecu , special key - D0 BD 4C 3F 3B DA 68 9C .
abdulrauf (6th July, 2022)
Broken device.
The device does not read the key inserted, in the cgdi itself.
I tested the coil signal, from the device. It is ok.
The ir led readers, these have been replaced last year.
And all worked fine.
Until today,
How can i test my device?
Beside the coil test.
Greetings Rob
Try this
https://youtu.be/uHfa5H_I6Ns
This would indicated that the ir diodes, in the device failed to work.
I will have a look inside.
Thank you
rob h (26th June, 2022)
I took it appart,
Under the usb microsope,
Soldering was fine.
A small hair, it was ennough to stop it from working.
Did the test, and it worked like before.
Thanks guys
Thanks to babeh for post 2176 ... added a video for that
https://www.youtube.com/watch?v=ErGC...el=heshamessam
wbr.
Hi!
Glk 250 cdiX204 (2012). All key lost! I programmed KeylessGo but work as a ordinary key. I used 41 rom, key CGDI Keyless. Does anyone know what the problem is?
