Results 1 to 8 of 8
    Nov 2011
    EU
    Default Iveco NewDaily 3.0d 107kw TVA OFF
    Hello
    I need throtlle body off here
    Ecu is edc16c39
    Nov 2011
    EU
    Manufactured dtc is 28B
    problem is because I do not have pcodes..
    Only this fault:
    Short circuit to ground on throttle valve actuator
    And if flap is disconnected, one more:
    Throttle valve actuator: open circuit
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Limp mode when disconnected?
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
    Nov 2011
    EU
    Quote Originally Posted by Ignasvw View Post
    No, car goes normally... obly edc light
    johak's Avatar
    only dtc....
  6. The Following User Says Thank You to johak For This Useful Post:
    bugarcek (7th September, 2017)
    Nov 2011
    EU
    Thanks. I hope throttle is the reason why car was not starting well
    johak's Avatar
    is there now dtc 28B?
    Default file
    here u have try Bosch Software Number 1037378086P_315V91ECU Type EDC16C39-5.A3
  10. The Following User Says Thank You to mb7361 For This Useful Post:
    bugarcek (11th September, 2017)
