Results 1 to 11 of 11
    Junior Member kari's Avatar
    Finland
    Default Sudo no password
    Here’s how you can set Ubuntu to not prompt for your password when using sudo.
    Launch a terminal window and enter the following command:
    # sudo visudo
    Visudo is a tool used to edit the configuration file of sudo . The command will prompt your for your password. Enter it one last time. The configuration file will open in a text editor, most likely Nano. Scroll down to the end of the document and add the following line:
    username ALL=NOPASSWD: ALL
    Replace username with the username of the user you want to allow a passwordless sudo. So if the user is kari, you would enter:
    kari ALL=NOPASSWD: ALL
    Save and exit the file. Log out, log in as the user kari and test out your new passwordless sudo.
    Note: this is something that is not recommended if you are using your computer in a public place or at your work
    Thnx!
    Very usefull post
    Quote Originally Posted by kari View Post
    Here?s how you can set Ubuntu to not prompt for your password when using sudo.
    # sudo visudo
    Beware of that you are serving yourself in silver plate with root privileges. That's why we are using sudo with pass for your security.
    They are right. You should only run things in root if you really need to.
    Root is dangerous if mis-handled
    Very useful, post thank you!
    Jeremias
    It would be safer to limit the scope of "no password" through CMD_ALIAS. For example, I skip the password for reboot, shutdown, mount, and umount only.
    Quote Originally Posted by rwl408 View Post
    By the way, be extremely careful when you "su visudo". It is too easy to mess up things and I had to boot to recovery mode to fix it a few times.
    Greece, Hellas
    I think that you shouldn't do it, cause it is not so good for your security m8. You increase vulnerability with that thing
    Sep 2010
    I will never do that on my Ubuntu computer.
    Member radu_gostian's Avatar
    And that s how you make your account to a root one .
    Why bother with that account just use root account instead
    Oct 2010
    very usefull post, thanks for post
