Results 1 to 9 of 9
    ireland
    Default HYUNDAI i40 1.7 EDC17C08 DPF OFF
    Hi,Need help turning off DPF in hyundai i40
    0 281 018 491
    39120-2A208
    D4VF5WLMCVELIT2U
    best regards
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    PRESS THANKS AND REPUTATION button. pass pm. Your dpf off
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
  3. The Following User Says Thank You to Ignasvw For This Useful Post:
    mendox (8th September, 2017)
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    delete your inbox. pass igntune
  5. The Following User Says Thank You to Ignasvw For This Useful Post:
  6. #4
    johak's Avatar
    I was late
    Sep 2013
    Quote Originally Posted by Ignasvw View Post
    Disabling several error codes and changing the switches that do not relate to the particulate filter - bad solution. It will not work!
  8. #6
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    It works mate
  9. #7
    Sep 2013
    It works mate
    Changes in the Array to define availability of gear information via CAN allows you to disable the operation of the particulate filter?
    Open your damos and see where did the changes "dpf remover".
  10. The Following 2 Users Say Thank You to pike For This Useful Post:
    Babos (9th September, 2017), bobolin4o (9th September, 2017)
  11. #8
    johak's Avatar
    if the Ignasvw solution does not work
  12. The Following 2 Users Say Thank You to johak For This Useful Post:
    autoelek (11th June, 2019), mendox (9th September, 2017)
  13. #9
    ireland
    thanks guys for the help
    with johak soliution working
    with ignasvw soliution after drivig I have fault p2002
    thank you very much
    best regards
