Brake lights must work, very important. Check for burnt pins in rear light cluster plugs. make sure large plug at rear of gearbox to main loom is in good condition and clean contacts.
hello my friend i have car opel meriva 2005 engine z16xe this car auto i see on dashbord flashing --F-- AND CAR DON T STARTING
I have DTC in MTA easytronic
P 1703-4 Brake light switch signal can -bus malfunction
and in
abs/esp
c0161-4 brake switch circuit open
and in
motor p1700-a service vehicle soon request from transmission control module
all this DTC PRESENT i cant removing it
and i changing Brake light switch same problem and checked the wires
any one have info for this problem
AHHH i will see that
car is running now but it don t go i will see what the problem tomoro thanks
Hi mate,
I have same car with dtcs on abs:
C0161-00 ABS/TCS Brake Switch Circuit Malfunction
C0131-5A pressure sensor faulty
The problem came when I changed it by donor one.
Any idea how to fix it please?
Thanks a lot
Meat-Head (22nd January, 2020)
Can you explain more about what you changed and why
alclot (22nd January, 2020)
Hi mate,
I change only hydraulic part from donor one and after that the abs gets these dtcs. Perharps it is faulty. Tomorrow I´m going to try another one.
I was learning about these dtcs and the problem looks sensor inside hydraulic part.
Thanks a lot
