No Try cancheck........... %100 off code same
hello friend
please i need code for this file thanks
hi there are program to remove cancheck ?
Hi, I need to disable the cancheck on Panda 169 car radios I read the eprom 95320, I attach the .bin file you could disable the cancheck, thanks [ATTACH] 650320 [/ ATTACH]
Thanks tomorrow I try
Hi to all.
The radio is Fiat BP9374.Bp7394-25160BP.rar
This is my orig bin.I know a code (6422)
Is it possible to be remove the cod?
Thanks.
Hi my friends,
I made cancheck off by blaupunkt GMBH Lancia 843 II MYC1V2 MP3 as dump attached,
It works, but it turn OFF after 20 minutes.
Is there a solution that always works?
Hi please help disable cancheck on my radio have no idea how to edit this file.
Also if someone knows how to activate the AUX-in without a cd changer I would appreciate it.
Hi my friend,
try this and report.
I'm not sure
thanks for the quick answer took me 2 days to figure out how to programm the chip. turns out the settings i had worked for reading but not for writing. After putting the chip back in however I do still get cancheck. So whats next?
Thank you very much in advance
Do you know if the EEPROM contains just data or also code?
was wondering if it could be reverse-engineered.
Thank
