Page 1 of 11 123456 ... LastLast
Results 1 to 15 of 152
    Default cancheck on blaupunkt radio
    hi to all,
    i hope that someone here can give me an hand.
    I have a blaupunkt radio car.
    MODEL: ALFA947 GTA MP3 SB05
    SN: BP635769345313
    FIAT NR. 156 074 559 0
    I have the code for that, but since i'm tryng to install it on a car that does not have the BODY COMPUTER, the radio tell me CAN CHECK and stop there..
    I cannot find nothing for this model, i can post photos and dump of the memory M95320 ( 25C320)
    I would know if someone knows how to decode this dump
    (i think that should be similar to other FIAT radio car, even if this was on an ALFA 147 car)
    Dump is in attachment
    morocco/fbs
    Talking
    are 2 types of alfa937
    one with code in eeprom 95320 other with code in MCU HC11PA8
    both can be unlocked, also can be removed IMMO protection
    Jun 2009
    Quote Originally Posted by jokersat View Post
    with what did you remove it?
    Jun 2009
    Yes..true! Both model can be easy done! Need to edit few adress from eprom!
    ok, thank you to all for the answers.
    i mounted the 95320 file sent by jokersat, and no CANCHECK but nothing at all onto the display.. it is regular? I only given +12V and ground to the radio. shouldn't start?
    EDIT: inserted a cd, now i cannot even eject it:P none of the button except on/off is ok.
    In add the file you sent me it is not taken from my dump but something else.
    Can someone explain what bytes to modify to remove this cancheck?
    Jun 2009
    So..dump posted from jokersat is not for your car radio!
    You need to write THIS dump! Password for rar is in your PM!
    Good luck and post result!
  7. The Following 3 Users Say Thank You to djdansmart For This Useful Post:
    gamsahurd (20th December, 2020), ouragh (17th December, 2017), STTaG (4th November, 2016)
    ehi friends ALL OK!!
    RAdio is working good
    Really thanks to djdansmart for is invaluable help
    (and to all the others for their time)
    Now i would be really happy if someone can explain me difference between IMMO and CAN CHECK Are they the same?
    Even if it is ok, this dump is not from mine, no one knows what to edit into eeprom dump to remove can check and read code?
    (in my first dump the code is 2555, but may be is someway chipered into the dump because there isn't that bytes nor normal, nor reversed)
    In conclusion, this is a great forum!
    I hope i can give my contribute as soon as possible
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by djdansmart View Post
    So its a seacret then mate....We love them here,,,,Or are you testing an idea...??
  10. #9
    adam28's Avatar
    May 2009
    UK Essex
    Default i
    This is the tool used for fiat radio cancheck this is a demo by TMW eletronics, but i know there is a cracked version out there. Does anyone have it to share.
    Adam
    NEVER GET SO BUSY MAKING A LIVING THAT YOU FORGET TO MAKE A LIFE......
  11. The Following 7 Users Say Thank You to adam28 For This Useful Post:
    barto41 (26th January, 2021), fiammifero1 (5th February, 2021), gamsahurd (29th January, 2021), gogoli (16th January, 2023), karageorgos (14th April, 2019), paradajz (23rd September, 2021), slav77 (31st March, 2018)
  12. #10
    V.I.P. Member milanoffracing's Avatar
    Bulgaria,Sofia
    Quote Originally Posted by adam28 View Post
    Adam
    Here is, run loader for work
  13. The Following 15 Users Say Thank You to milanoffracing For This Useful Post:
    barto41 (26th January, 2021), daquima (21st December, 2016), fiammifero1 (5th February, 2021), fr3nsis (31st March, 2018), gamsahurd (29th January, 2021), gogoli (16th January, 2023), hp7909 (23rd March, 2023), jebson (6th April, 2017), laurentiudania (8th August, 2023), marsete (14th January, 2019), nelsoncaseiro (29th June, 2020), ouragh (17th December, 2017), paradajz (23rd September, 2021), serbi (7th September, 2020), TECNO3 (2nd May, 2018)
  14. #11
    morocco/fbs
    95320_cancheck_programmer_v1.0
    for fiat punto and other
    this tool is simple interface and wiring conection
    pass : jokerdiag
  15. The Following 17 Users Say Thank You to jokersat For This Useful Post:
    barto41 (26th January, 2021), cucak (19th April, 2018), damil (23rd October, 2019), fiammifero1 (5th February, 2021), gamsahurd (20th December, 2020), Georg34 (6th February, 2022), gigimercedes (19th May, 2017), gogoli (16th January, 2023), mario.ie (16th March, 2016), nelsoncaseiro (29th June, 2020), Salkhi (29th June, 2023), sarigol45 (18th November, 2016), saztek (24th November, 2015), shox82 (30th December, 2017), shpuncik (10th March, 2020), vavrich (16th September, 2019), videovox (15th December, 2017)
  16. #12
    Default 95320_cancheck_programmer_v1.0
    For All NO RAR Password !
    Regards!
    Do not forget to press thanks button!
  17. The Following 30 Users Say Thank You to wilcoboy For This Useful Post:
    aldorex (14th November, 2016), asliyucegsm (27th June, 2016), cadaseda (18th July, 2017), damil (23rd October, 2019), Diavoletto (30th August, 2017), dttamas (7th July, 2022), elektromax (24th February, 2014), elfq (16th September, 2019), gamsahurd (20th December, 2020), Georg34 (6th February, 2022), gigimercedes (19th May, 2017), gogoli (18th November, 2013), jebson (6th April, 2017), julo45 (23rd April, 2014), karageorgos (14th April, 2019), kewogoc766 (10th January, 2024), konop11138 (22nd February, 2016), ltb (13th December, 2016), Macchinista (28th October, 2019), monzz (28th January, 2018), nelsoncaseiro (29th June, 2020), nnasskoo (6th July, 2019), ouragh (17th December, 2017), sathex (28th May, 2021), saztek (24th November, 2015), serbi (7th September, 2020), skens (2nd July, 2014), slav77 (31st March, 2018), smaiki (12th April, 2019), videovox (15th December, 2017)
  18. #13
    morocco/fbs
    you can explain how it work
  19. #14
    Jun 2009
    And where is HEX file for PIC??
  20. #15
    Nov 2008
    Thank you ....... work perfect.....for me.
    BR
  21. The Following 5 Users Say Thank You to v11 For This Useful Post:
    gamsahurd (29th January, 2021), hafid2 (16th July, 2013), intikman (7th October, 2014), mohenddo (28th September, 2015)
