Results 1 to 5 of 5
    Jun 2016
    Default EDC16cp31 EGR/DPF OFF
    Hello !
    Please, i need DPF/ EGR off for my Mercedes sprinter 3 313 CDI 2007
    NIV: WDB9066331S172133
    I have already tried with ecu safe 2.0 but it does not work with EGR, it works only with DPF.
    Because after i disconnect the egr it goes in degraded mode but it does not show a dtc.
    in MPPS
    selected ecu: 2.2 CDI Bosch EDC16cp31
    Mercedes Ecu type : Bosch EDC16+/EDC16C
    Thanks in advance.
    johak's Avatar
    hi
    here is your file
    please report
    Jun 2016
    Thank you,
    I'll gonna try it and i'll tell you the result.
    Just a question, could i disconnected thr EGR after that ?
    johak's Avatar
    can be disconnected
    if it works, press rep + thanks buttons
  5. The Following User Says Thank You to johak For This Useful Post:
    fmcdiag (16th September, 2017)
    Jun 2016
    Thanks Johak ! it works very well.
