Results 1 to 12 of 12
    Oct 2016
    Default mitsubishi center fuso 3.0 dtc off P0101
    A colleague or someone would help me to turn off this error. I have a problem with this car such an error can not be removed even on the engine off Exchange replacement for the second installation checked twice as if the computer was damaged I swapped nothing changed The second driver can not get The administrator has stated on the site is a crashed driver and they can replace it for the second after the regeneration and how old will be the discount but the price of the cosmos could be log off these dtc autko walks normally and the parameters sees the signal from the flowmeter
    chipdanix's Avatar
    Apr 2016
    Poland - Warsaw
    Nobody one knows everything we learn a lifetime
    repair ecu , dtc , dpf , egr ..........
  3. The Following 2 Users Say Thank You to chipdanix For This Useful Post:
    drewdom (16th September, 2017), konq100 (16th September, 2017)
    Oct 2016
    Tomorrow I will test it again
    Oct 2016
    chipdanix chip error P0101 still has this eeprom error but you can remove it
    Apr 2014
    http://www.digital-kaos.co.uk/forums...highlight=fuso
    hi chipdanix
    i need immo off ,mitsubishi center fuso 3.0
    Sep 2012
    Hi all
    i have got same issue, any solution ?
    pike's Avatar
    Sep 2013
    Hi.
    Upload your file.
    Sep 2012
    Quote Originally Posted by pike View Post
    Hi.
    Upload your file.
    File attached
    thanks in advance
  10. #9
    pike's Avatar
    Sep 2013
    Arrow mitsubishi fuso 3.0 dtc off P0101
    DTC P0101 off
  11. The Following User Says Thank You to pike For This Useful Post:
    grygry (15th April, 2019)
  12. #10
    Sep 2012
    unfortunately i havegot still P0101
  13. #11
    Sep 2012
    is there anyone who can solve this issue as professional?
  14. #12
    Babos's Avatar
    Mar 2012
    I can write me in PM.
