Model?
There is no such, there is another value!
Model?
You'll need pictures from all sides mate .... ? PremierD
Model is GDP40 and 24749mth
and i measured this pinouts and first picture correct.
mth solved, problem solved
zrt997 (16th March, 2019)
Do you have firmware with mcu St92f150cv?
Mate how did you read this what tool?
Hi can Iask you how did it went with your YALE forklift GDP40 year2010 ?
I am working on the same kind and they say that there is 2 memory
for this modele of yale one in cluster and one in bcm and that the higher
value copy to the other ...
thanks for your reply
Hi can I ask you how did it went with your YALE forklift GDP40 year2010 ?
thanks anyway !
found the solution
everything done !
Can you please share how you finished this job and is there two memory or only one in dashboard?
Regrads
Mackie
" I don't need help but difficulties. The harder the better. I work the best when in trouble."
It's very easy to do.
Can you please share it ?
Mackie
Anyone can fix working hours in this dump(st95128) ? Try couple solutions but old hours come back . Is there BCM in this model or working hours are in dashboard only ?
I have 22493 i need 2493
Mackie
Here is same Forklift with new working hours. If someone can menage how to change it to 2493.
In this dump now there is 22503 hours.
Best Regards
Mackie
Here is the file
MACKIE (5th January, 2022)
