Results 1 to 14 of 14
Hybrid View
    Feb 2016
    Default DDE 8 CAS3+ ISN security code help please
    Hi, long story short: original ECU eeprom corrupt, i have only full backup with KESS. I wrote to original ECU exact the same software(donor) but ISN in eeprom is different. After that i overwrote full_backup_kess, but ISN didnt change. I have CAS eeprom, ECU eeprom(new), original ISN code from CAS and key info - all in attachment. Can somobody write that ISN to ECU eeprom? If i do it manually, it doesnt work - i think you need checksum around 3 lines of ISN... I did also immo off in flash, but there are still fault codes and red light in dash. Please help.
    Thank you
    Al
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    ISN: 3A3F0E196F088916BB1EDFBBE14DA9D5
  3. The Following User Says Thank You to CarCity For This Useful Post:
    Zaklberg (24th September, 2017)
    Feb 2016
    Thanks for reply, can i overwrite this ISN in ECU eeprom? What about checksum?
    Al
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    Yes you can write ISN to ECU
    or
    synch DME and CAS with VVDI 2
    best regards
  6. #5
    Feb 2016
    Ok, i wrote ISN to ECU eeprom, but still gives me error 2E3B EWS manipulation. I also tried cas dde synchronisation with vvdi2, but it is not possible. Any other solution - maybe can you write ISN from ecu to CAS?
    Al
  7. #6
    kiszka's Avatar
    Aug 2009
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
  8. #7
    Feb 2016
    Ok, original CAS eeprom and ECU eeprom with donor ISK.
    Al
  9. #8
    kiszka's Avatar
    Aug 2009
    Reality of life :
    4:Everyone lies
  10. The Following User Says Thank You to kiszka For This Useful Post:
  11. #9
    Feb 2016
    Thank you for helping, sir, but the folder is empty i think
    Al
  12. #10
    Mar 2013
    Europe
    FVDI can do
    Snycro ---> CAS and ECU
  13. #11
    doctore's Avatar
    Nov 2015
    Colorado Denver
    no need syncro on long isn and cannot duet
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  14. The Following User Says Thank You to doctore For This Useful Post:
  15. #12
    Feb 2016
    I also think all i need is that ISN from my first post to be written in ECU eeprom. That should work - i copy ECU eeprom from another car into my ECU and put it into that car and it started - no ews manipulation(with a bunch of error codes...). I think problem is in eeprom checksum - ISN is repeated 3 times and aroud it are different bytes(i guess checksum).
    Al
  16. #13
    kiszka's Avatar
    Aug 2009
    Reality of life :
    4:Everyone lies
  17. The Following User Says Thank You to kiszka For This Useful Post:
  18. #14
    dijo's Avatar
    Apr 2010
    You have 2 option...
    1-You change ISN in ECU dump and post here Ori dump and dump after written ISN...
    2-You change ISN in Cas but you need to read "real page3" in your working key...
