After several ignitions after the smart key reset, the ignition does not turn on. How can i turn it on again with the teachstream or should i do the smart key reset again?
Can anybody please help?
I can't program the smart key on Toyota Highlander Hybrid 2009. It does not finish the procedure when it says to place the key on the seat and there it can't see the key anymore. I checked under the seat and there's no key, i also checked the middle console but still could not find the antenna. Anybody got a picture where I can see the location of the attached antenna?
Thanks in advance!
I have 2 error: B2289- Key collation witing time over and b2784- Antenna coil open/short ( I could not find this antenna ). How to turn on the ignition ?
The Start button or smart ecu is Bad OR Both! i had same thing on 2008 Camry after some one was welding repair the car with 12v battery connected.
Tariel (29th September, 2017)
You must of scramble the iD box. Try sync the system ground out 4&13 for 45 min with the button "on".
also the light trigger on door keep push it to reset. If that does not work then follow these.
1. Pull out iD box (behind the blower and firewall) reroute it behind the glovebox. Put the dash back together.
virginize the iD box. Reason for reroute make it easier for you to get to the iD box. You might have to do these a few times. Due to the iD virgin file might be bad. It took me 5 try's before it started.
2. Do immo. Reset 16min.
3. Register the iD box to the button
4. Sync the immo. To the ecu 4/13 for 45 min.
5. Start car.
alclot (13th December, 2019), djeuroalex (1st October, 2017), McDowell (17th December, 2019), Tariel (29th September, 2017)
Thanks ray-ray .
Is there any other way except removing the ID box? I have never removed an ID box.
if you get the beep that means it sees the key
so coil is fine in button
Hi mates,
I have RAV4 with ecu 89661-42C00 - 175800-7734 and smart key. The dtcs is B2289 and when I push start button dont get on becuase car doesnt recognize the key. Can anyone help me with that?
Other problem is where is the location of immo box. So hard to take out
Thanks a lot
