Results 1 to 3 of 3
    Default clone R3v? flash. can we reset the points?
    4ve been offered R3v0 flash tools.
    Told to be realy easy to tune vag.
    Want to try one, if they change the price a little.
    It is working with point credits programmed in to it. when you use it. it will cost you points.
    Could it be possible to take a backup. and when you used the points to reset to new. ;-)
    Or could there be way to update your points. ;-)
    Netherlands
    If you tune with this and want to change to ori then you have much more less power then original! After this it is impossible to tune again. I have seen this a lot of times.
    Why would it be impossible to go back? you need good tool and some knowledge yes. but they don't make it impossible.
