Upload ori too.
Wysłane z iPhone za pomocą Tapatalk
Hi, i got a remap for a Jeep Grand Jerokee 3.0 CRD EDC16, the file should have egr off, cat off and swirl-flaps off and also stage 1. But if i drive the car it has power until 80 kph and then it goes in kind of a limp mode and the power is really low. There are no dtc in the ecu and the "limp" mode stays until i switch the ignition off and on again. Can someone please check the remapped file?
Upload ori too.
DSG TUNING
File Service
Hi ori file is now also in the first post. thank you
yes egr is disconnected, i bought this file but the seller said with file everything is fine. so i changed everything fom turbo, boost controller and so on at this car but still doesnt work. can someone please help me?
hi yes with original file i have errors and limp mode because of bypassed egr and swirl flaps so i really need a working solution
the solution on this file is not complete,
CVN FIX Vag/Bmw
Tuning Petrol and Diesel
High Power Maps
Custom Tuning Stage 3+ Hybrid
Dsg Tuning
Try this file.
stylesp (5th October, 2017)
Thank you i will try it tomorrow.
I tried the file but no chnges still limp mode but maybe i found the reason, i ordered a new throttle. I tell you the results.
