Results 1 to 15 of 19
    ascrap2003's Avatar
    Sep 2016
    Texas
    Default 2010 W204 First Time Miles Correction
    Ok have one to do and have never done a mercedes before, i have read and searched forums but a lot of info is confusing. I know there is mutiple ways to do a benz but need someone to walk me thru.
    I read keep car in start, eis blah blah.
    So please explain like Im 5 years old.
    I have usa prog, digiprog clone, vvdi prog, x100 pro, Car prog & Maxi Sys 906bt
    Whats the exact proccess?
    A.
    1. Disconnect battery
    2. Touch Batt Cables toghether
    3. Remove Cluster Read & Program Eeprom
    4. Install can filter into cluster harness
    5. Reconnect Cluster
    6. Connect Batt & Start car?
    B.
    3. Remove Cluster & Install can filter into cluster harness
    7. Program Cluster Mileage Via OBD?
    C.
    5. Remove Airbag & Steering Wheel
    6. Remove EZS
    7. Program EZS or Install Can Filter Into EZS
    8. Reinstall EZS, Cluster, Steering Wheel, Airbag
    9. Connect Battery & Start Car
    D.
    3. Remove Cluster
    6. Remove EZS
    10. Program Mileage Via OBD
    E.
    1. Put car in on position but not running
    2. Remove Cluster
    3. Program Cluster EEPROM
    4. Install CAN filter into cluster plug
    5. Re install Cluster
    6. Start Car
    F.
    1. Do not disconnect battery keep car off/key off
    2. Remove cluster program eeprom & install filter on cluster
    3. Re install cluster
    Sorry for so many questions I read horror stories about "------" & "999999" Miles and I dont have acess to
    MB star, Abrites, AVDI, FVDI or anything like that so i need it done right the first time no head aches!
    Thanx for your support & knowladge in advance!
    Had a issue Had a issue with my uploads so if you see one of my posts and need that dump let me know and I'll post it!
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by ascrap2003 View Post
    A.
    B.
    C.
    6. Remove EZS
    D.
    3. Remove Cluster
    6. Remove EZS
    E.
    2. Remove Cluster
    6. Start Car
    F.
    Ooooouuu ...............mate
    Its simple to do .
    1.just disconect battery.(no need this like ...... Touch Batt Cables toghether.....)
    2.Ebaut can filter install ( into cluster plug,into cluster harness or in EZS)
    3.For kluster 2 sulution.
    1.
    Open kluster and do it job with eeprom only safe original damp. .Recomended,because if eny trable you have original.
    Conect battery.Erase fault.
    2.
    Conect battery,do it job by obd2 (Digiprog to do 100%) and erase fault.
    Thats all.Good luck.
  3. The Following User Says Thank You to brend For This Useful Post:
    ascrap2003 (30th September, 2017)
    diagtech2000's Avatar
    Jul 2013
    North of England
    just use your digiprog clone , go to w204 c class then ezs option and then program required km, mo need for can filter
    Please hit thanks if this helped you!
  5. The Following User Says Thank You to diagtech2000 For This Useful Post:
  6. #4
    ascrap2003's Avatar
    Sep 2016
    Texas
    Do i have to check digiprog wiring? which connector? So 2010 W204 no filter needed just choose EZS option instead of tacho option?
    When ever I read OBD with Digiprog it always says 0 miles or a mileage other than what a car has so I have never programmed because it scares me.
    ascrap2003's Avatar
    Sep 2016
    Texas
    Quote Originally Posted by brend View Post
    Its simple to do .
    1.
    2.
    Which mercedes can be done like this? Most W203, W204, W211, 212, W219 etc
  8. #6
    brend's Avatar
    Oct 2015
    Same where
    W204,W212,W221,W216,W207 Where is UDS protokol.
  9. #7
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by diagtech2000 View Post
    Digiprog clon not to do Ezs in this car.
    Digiprog3 clon > EZS - NO SULUTION Or Just killer for this .No recomended.
    > Dash- yes and good by obd.
  10. #8
    ascrap2003's Avatar
    Sep 2016
    Texas
    awesome thanx for the great info, will my maxisys 906bt be good enough to clear any errors? and edit assyst?
    whats the assyst proccess on the list? Should be done last after battery connect and vehicle start up?
  11. #9
    Aug 2015
    BEHIND YOU
    Just do the job like brend told you. I have do more then 50 + never had a problem. Just go to menu w204 and only do ezs. Do not be afraid because dash will show 999999 for about 20 ~~~~nd then it will go exactly to the value that you have choose. After that there is a option on w204 list with digiprog CLR error. Press it . Dont be also affraid abs and esp will light on on dash . Then after about 20 s all is ok.
    if dealer do a full scan with star he can see that the ezs is 1.6million km.
    good luck
    IF MY POST WAS HELPFUL DON'T FORGET TO GIVE ME LIKE AND REPUTATION... THAT WILL KEEP US HELPING OTHER'S
  12. The Following User Says Thank You to eliaselias For This Useful Post:
    ascrap2003 (29th October, 2017)
  13. #10
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by eliaselias View Post
    good luck
    Not all can filter to do this like you see in EZS 1.6 million km.
    Another filter shwo km in ezs like have dash.(i use this).
  14. #11
    brend's Avatar
    Oct 2015
    Same where
    For clear fault this tool enough.For edit asist or all car edit, you most have moor experience and another tool ,because its not simple.
    Just dash-----simpel.
    All car edit----- not simple.(you most have experience fot this )
    Good luck.
  15. The Following User Says Thank You to brend For This Useful Post:
    ascrap2003 (2nd October, 2017)
  16. #12
    ascrap2003's Avatar
    Sep 2016
    Texas
    I also have Carprog Original Basic Can This Do Assyst / assyst + via direct epprom read? In circuit?
  17. #13
    ascrap2003's Avatar
    Sep 2016
    Texas
    good luck
    Brend said not to Do EZS with clone "will kill dash" look up
  18. #14
    XmoDDeR's Avatar
    Mar 2011
    putting salt on leeches, one grain at a time!
    and it has ended that was like reading the novel moby dick.................. long read
    Reading is fundamental, asking is easy............................
  19. The Following User Says Thank You to XmoDDeR For This Useful Post:
    eliaselias (3rd October, 2017)
  20. #15
    Aug 2015
    BEHIND YOU
    mine is clone of clone
