Results 1 to 8 of 8
    Apr 2012
    Default OPEL CORSA 1.3 MJD 603.S7
    Hi people.
    Was very hard for me found this full ktag read.
    I give for all this ktag read.
    the ecu is 55568002KQ.
    OPEL CORSA D 1.3 MJD 603.S7/HW/03A/3137-S860.
    REGARDS
  2. The Following 9 Users Say Thank You to hp1275 For This Useful Post:
    2hard (5th December, 2019), auto421 (11th March, 2021), buddycz (7th January, 2023), eeprom241 (26th February, 2021), garageozcar (28th September, 2018), gtcricardo (17th February, 2021), ivvi 2 (11th July, 2018), marek128 (22nd January, 2019), tomo776 (21st May, 2022)
  3. #2
    Jan 2017
    with what machine did you read this? Trying to read this same ecu without success with both ktag and galleto, both say micro not supported.Thanks
    Nevermind, already readed the ecu, problem was with the ktag adapter, I tried to read directly with wires soldered to the flat cable and readed fine after.
    Last edited by vitorponte; 30th December, 2018 at 11:21 PM. Reason: solved the problem
  4. The Following User Says Thank You to vitorponte For This Useful Post:
    joaopereira6 (15th January, 2019)
  5. #3
    Jan 2014
    Portugal
    Obrigado Vitor.
  6. #4
    Sep 2015
    Can do full boot read on these ecu's via obd using I/O terminal + Magnetti Marreli plug in.
  7. #5
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    And mpps can full read-write that ecu.....
    Is that ecu so hard to find? I have full bdm reading
    Of a MJD 6O3.S7/HW03A/3137-S860. S4400 Z13DTJ 119g ....
    If anyone need pm me....
  8. #6
    Jun 2019
    i can not download it, please atach again
    Quote Originally Posted by hp1275 View Post
    Hi people.
    REGARDS
  9. #7
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    You do something wrong...
    I just download the dump....
    Try again....
  10. #8
    Oct 2010
    portugal Coimbra
    Default thanks for share it
    Hi people.
    REGARDS
