Results 1 to 4 of 4
Hybrid View
    Apr 2017
    Poland, Poznań
    Default EDC17CP02, need some help with my mappack
    I'm just working on mappack to remap (light stage1 for about 200ps/400nm) my friend's 320dA E91 177hp. Ori file (+mappack) is in attachment, I've read it with kess using boot mode (if anyone needs, I have full recovery). I've created a mappack, whole map list is below. My question is at first - where is single bit of deviation for torque (8 bit to change from 128 to 255). Also if I correctly done all of torque limiters or some need to be added or have bad address (also DW limiters) ? It seems, thet I've lost some SVBL (not sure, in my 318d DDE8 there isn't any) or SVRL. I'm not going to add more than 100 mbar of boost, it also need to have DPF in good condition, so lambda rather wouldn't be lowered more than 3-4%. Any help will be apprechiated with thanks
    HW : 08512498
    SW : 1037509478
    Map addresses :
    4060A SVTQL ??
    43628 Torque limit 8x12
    4A9F2 SVTQL
    4AA26 SVTQL
    5109C Driver's wish 8x14
    511AC Driver's wish 8x14
    5821A Torque limit 10x1
    5829A Torque limit 8x13
    583CE Torque limit 5x16
    58634 SVTQL
    587B0 Torque limit 21x1
    5880E Torque limit 3x21
    58938 Torque limit 21x1
    58994 Torque%reduction EGT 9x9
    58A5E Torque%reduction EGT 9x9
    58B42 Torque%reduction oil temp 7x7
    58BC4 Torque%reduction oil temp 7x7
    5C08A SOI map 16x16
    5C2CE SOI map 16x16
    5C512 SOI map 16x16
    67B8A Duration 40x16 (badly defined in my mappack as 16x40)
    69922 N75 16x16
    69B66 N75 16x16
    69DA2 N75 16x12
    69FE6 N75 16x12
    6A22C N75 16x13
    6A470 N75 16x13
    6A6AE N75 14x12
    6A842 N75 16x16
    6BA16 Boost 16x16
    6BC5A Boost 16x16
    6BE9A Boost 16x14
    6C0E2 Boost 16x16
    6C324 Boost 16x15
    6C568 Boost 16x15
    6C7AE Boost@regeneration 16x16
    6C9F2 Boost@regeneration 16x16
    6CCB8 Boost limit via Patm 14x16
    6E2C0 N75 16x16
    724E8 Nm to IQ 16x16
    7272C Nm to IQ 16x16
    72970 Nm to IQ 16x16
    72BB4 Nm to IQ 16x16
    72DF8 Nm to IQ 16x16
    741A2 Rail limiter 12x8
    74B28 Duration 16x16
    74E72 Rail limiter 12x8
    74F68 Rail map 16x16
    75168 Rail map 16x16
    75562 Rail map 16x16
    7589A Rail map 16x16
    76FC8 Torque limiter 8x21
    787D2 Torque limiter 10x1
    787F8 Torque limiter 1 gear 8x1
    7881A Torque limiter 2 gear 8x1
    7883C Torque limiter 3 gear 8x1
    7885E Torque limiter 4 gear 8x1
    78880 Torque limiter 5 gear 8x1
    788A2 Torque limiter 6 gear 8x1
    788C4 Torque limiter R gear 8x1
    7B0C0 Lambda 16x14
    7B304 Lambda 16x14
    7B548 Lambda 16x14
    7B78C Lambda 16x14
    7B9D4 Lambda 16x16
    7BC18 Lambda@regen 16x16
    7BE58 Lambda 16x14
    7C09C Lambda 16x14
    7C328 Lambda 16x14
    7C56C Lambda 16x14
    7C7B4 Lambda 16x16
    7C9F8 Lambda@regen 16x16
    Feb 2014
    Spain
    Hello
    I think it is at 434B3.
    74B28 is not Duration.
  3. The Following User Says Thank You to biela For This Useful Post:
    fzhut (4th October, 2017)
    Apr 2017
    Poland, Poznań
    Any more advices ? 4 downloads, I belive thet not only for use my mappack, but also for help.
    Mar 2015
    there is no need for your mappack !
    this ecu is simple to tune if you need help to tune it i can do it in realy simple way
    post fresh bdm flash read and wait untill i make one simple and strong smokeless
