maybe it's a nats system 6, read eeprom bcm 93c56/93c66
Hello, could someone help me out with the Nissan Murano 3.5 2005 Pin? It has replacement ecu and I need to sync the ecm with the immo (original ecm eeprom data is lost) so I need pin. I tried few softwares, the software gives me 6316 PIN which is not correct, launch, carmanscan gives - failed initialization. I attach the labels from ecu's, maybe someone knows the problem? At the momment fauls are in both immo and ecm ecus p1611.
I attach BCM foto, not really clear, but I think there is no PIN in the label.
Hi you need BCM number, from foto i think is 284B1, try pin 3546.
Milicija (7th October, 2017)
Thanks guys for your time, I attach the R56 read.
Maybe somebody has some thoughts about this problem? For me, its clearly that pin should be 6316. Maybe the initilization is failed, because there is ecu with different number - Original MEC63-760, new (used) MEC33-890? When new ecu is connected there is fault P1610 and when I crank the engine I get P1611 (Immo and ECM different ID)... The old ECM wasn't failed completely, but the EEprom data got corupted, I will try to put EEprom data from MEC63-690 (found dump) and see whats happens. Also tried adding key with FVDI, entered 6316 PIN, but came with wrong pin.... What could be problem of this?
Anyway, if someone finds this thread, and has familiar problem, the problem that 6316 (correct PIN) was not accepted, because the replacement ECU, had different numbers, probably IMMO system with BCM, thats why launch or other equipment could not make initialization. Got replacement ecu with same part number MEC63-760 and everything went smooth
hi
if your bcm number realy is 284B1
you have old pin witch is 3564
new pin is 4957
check and see
this should work if your bcm number is correct
kind regards mehmet
if use the last picture 6 digit code and 4 digt code and calculate pin then i get 8568 as pin code
try and let me know if the codes work
kind regards mehmet
Hi, maybe we have two pincodes before and after 2009. Before 2009 is 1276, after 2009 is 6316.
IMG_20171012_105631.jpgHi, maybe we have two pincodes before and after 2009. Before 2009 is 1276, after 2009 is 6316.
Hi, maybe we have two pincodes before and after 2009. Before 2009 is 1276, after 2009 is 6316.IMG_20171012_105626.jpg
