    Pyromaniak's Avatar
    Aug 2015
    ~~~~ing CZECH
    Default E46 2003 unknown problem
    Hi friends, i have here bmw e46 320D 150hp,automat , from 2003, the problem of this car is : When i drive and press gas pedal, car have poor torgue, when i depress and press gas, car drive like normal.
    Situation repeat when no pedal press. (on first press on gaspedal car drive poor, on twice press car drive normal)
    Car have only one dtc (auxuality heater)
    New turbo on car, egr new .... I m 5ft mechanic trying to solve this problem.
    Please help, i for 12 year of my praxis newer see problem like this.
    EDIT: I try compare and try reprogram flash with file from this forum, but problem its same.
    0281010565 1037361858 ecu number
    My English is little bit bad, but day after day is better. Like my experiences https://www.youtube.com/channel/UCdT...bx2Pc7WI4pWUWA
    My help not for free, press THANKS and REP, for make me HAPPY
    im not using passwords, my work is for this forum and members free
    EU
    Hi. How about some live data readings when the problem occurs and when the problem is gone?
    Maf reading , Boost pressure Actual/Desired , Fuel Rail Pressure Actual/Desired etc
    Btw, had a similar problem with BMW 330D after bad reconditioned Turbo was fitted. It sorted out that the Turbo built either too much boost pressure or no boost at all. Fault codes none.
  3. The Following User Says Thank You to ollync For This Useful Post:
    Pyromaniak (8th October, 2017)
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    Mate i have same problem few years ago!!! No dtc, low torque.. spend a lot of money... the problem was simple...
    injectors wire... change all wires from ecu to injectiors...
    Wysłane z iPhone za pomocą Tapatalk
    DSG TUNING
    File Service
  5. The Following User Says Thank You to maajkii For This Useful Post:
  6. #4
    Pyromaniak's Avatar
    Aug 2015
    ~~~~ing CZECH
    Thank you mates. i think turbo too, when i read live data only boost pressure is lower (300-400mb, but depress and press and its ok) i try turbo regulating valve tomorow.
    dariobmw's Avatar
    near THE NORTH FACE
    Same prblem kan be the pressure sensor on the intake ,( near the firewall is little bit unconfotable ) or ar told before turbo with bad regulation.
    I was in similar problem with a car was alot time stopped , the catalizer ( the second piece the one under the car bot the one near the turbo )
    i dont know why but if a diesel car stay slot time wthout engine running the catalizer result in damage ( same problem with an audi )
  8. The Following User Says Thank You to dariobmw For This Useful Post:
    Pyromaniak (11th October, 2017)
  9. #6
    Pyromaniak's Avatar
    Aug 2015
    ~~~~ing CZECH
    Hi, solved. Pressure regulation valve Thank you friends
