check out this damos
HW: 0281012144
SW: 1037377871
Spare: 55205068
I need damos % A2L files full of them need to start my DIY tuning. I have the original file. And I have the 260HP file that is on the car right now. And I needed to fine tune it. But I could not find a proper location? Please help
Emre2blue (10th October, 2017)
Are "EDC16C39" & "........C9" same ?
I was especially looking for my gauge pressure settings. You know Alfa 159 has already boost pressure gauge inside. My boost is more than 2 bars. And I could not see it inside. I want to find those locations.
this is edc16c39
This file is from opel ?
this file is from fiat
159 Damos is hard to find right? This file does seems to be 147
@johak , I've sent you PM, please check...
Hi friend,
you need to linearize the sensor on the map
and mount a 4 bar sensor
Ecu powered, Dtc, Egr, Dpf, Throttle, Flaps, Lambda, Hotstart, AdBlue, Evap, Nox, Speed limiter, Dynotest development.
kinketotua (13th October, 2017)
Can you explain more ? I know that ~0.2V is like 0 bars. And ~4.89V is about 3 Bars Absolute. And I have a margin of maximum 2 bars of boost. I know from the file. But in the gauge it is only 1.6 Bar of boost.
I know it. There is a map location it says something like this
Pressure = 1000 - 1200 - 1400 - 1600 - 1800 - 2000 - 2200 - 2400 - 2600
Duty = %11 - %22 -% 33 %44 - %55 - %66 - %77 - %88- %100
Only for the gauge.
you only want to increase pressure?
then it is sufficient to increase 1e1370
do you have a 260HP (file Tuning) with 1.6 bar of pressure? mm3? afr? time opening were calculated? pid?
send grafic dynotest please
@NOX , I've sent PM, The car was overboosting over 2.5bar maybe ?
Tuning List is here
1) 0445 110 308 Injectors - brand new
2) GTB2060VKLR turbo with 10+0 GEN II Billet wheel
3) 70mm Downpipe + 70mm whole exhaust system + custom mid silencer + two custom back silencer
4) Ported Head + New 4 angled valves to feed more air easily
5) Custom Billet Intake with bigger plenum + 72mm Input without Throttle body
6) Custom Billet Exhaust Manifold 5mm Thickness 304TI - Same volume as orgiinal manifold to keep the spool fast.
7) Custom 4Lt Water2Air Intercooler design
8) 17" Standart Wheels with M32 Gearbox. 225-25-17 Rıms
10) Balanced Crank
11) Whole New engine
12) New head from 2008 car, It uses different glow plugs only in "Beru"
13) New Pistons
14) Same Rods
15) +1 Bar Oil Pump
16) Now the car has original MAF & MAP sensors. But I have new 80mm MAF and 3.5Bar MAP sensor
17) I want to put 2.4Lt JTDM - MAF 0 281 006 048
18) I want to put 3.5 BAR MAP sensor - 0 281 002 456
19) I don't have EGR valve at all. Full EGR system is in the garbage.
20) I don't have SwirlValve
21) I don't have Throttle Body.
22) I don't have DPF. I only make a fake shaped middle silencer. And put the sensors on it. To con the government
I have %10 more injection quantity at injectors. And the reMap is opened up to %15 more quantity. with 1750Bar CR pressure.
