Results 1 to 4 of 4
    Default ford mustang speed limit remove
    hi friends i need your help about removing speed for ford mustang 2014 with 3.7 engine
    engine ecu part number DR3A-12A650-GG
    is it possible to remove speed limit with ford IDS if yes how ? or speed limit can be removed by flash if it can be done only by flash what tool can read this type of ecu
    king regards
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    ford ids-> module programming -> programmable parameters -> speed items -> disable speed limiter -> YES -> function succesfull. Regards
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
  3. The Following 3 Users Say Thank You to Ignasvw For This Useful Post:
    klonone (22nd June, 2021), naelraddad (4th January, 2018), teerak2uk (11th October, 2017)
    Quote Originally Posted by Ignasvw View Post
    thank you friend i did as you told me but it seem that the speed limiter is already disabled because when i wan to save new parameters i got no parameter was changed
    any way the max speed for this car is 190km/h can i increase themax speed with tuning ?
    regards
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    post flash
    DSG TUNING
    File Service
