Page 6 of 10 FirstFirst 12345678910 LastLast
Results 76 to 90 of 145
  1. #76
    Jun 2012
    Default g85 8k0953568G
    thank you janusz21 i will test
  2. #77
    Jun 2012
    Quote Originally Posted by janusz21 View Post
    tray this bin
    hello
    I have already injected a file with the same modifications line 000010 and 000020 the result was negative.
    I finally bought a new full g85, because the tablecloth was also broken thank you anyway.
    problem solved.
  3. #78
    Jul 2019
    far far away
    Can some1 help me out with my dump of 95080?
    It shows sensor defective - think someone while changing clutch overturned it - fault happened after this repair.
    Cheers
  4. #79
    ricked's Avatar
    Apr 2016
    Europe
    Quote Originally Posted by alpntrb View Post
    Cheers
    your file fixed...
  5. The Following 3 Users Say Thank You to ricked For This Useful Post:
    alpntrb (20th July, 2020), Vpaul (3rd April, 2023)
  6. #80
    Jul 2019
    far far away
    Quote Originally Posted by ricked View Post
    your file fixed...
    Worked like a charm! Thank you very much!
  7. #81
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    Hi friends
    Please I need repair this eeproms
    95080 for 8K0953568L
    25320 for 8K0909144D
    ----(( Solved Thanks ))----
  8. #82
    ricked's Avatar
    Apr 2016
    Europe
    Quote Originally Posted by CarCity View Post
    Hi friends
    Thank for your advance
    what is wrong with the 8K0953568L as i dont see error in file?
  9. The Following User Says Thank You to ricked For This Useful Post:
    CarCity (22nd July, 2020)
  10. #83
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    Internal system fault ( B1168 ) and because of this ( C10AC ) steering end stop not learn !
  11. #84
    Aug 2020
    How can i read or write eeprom 95080?
  12. #85
    ricked's Avatar
    Apr 2016
    Europe
    Quote Originally Posted by Smoogle View Post
    use something like TL866II Plus minipro, is cheap tool and works good, beware of clone/fake btw
  13. The Following 2 Users Say Thank You to ricked For This Useful Post:
  14. #86
    Aug 2020
    How to read or write without soldering?
  15. #87
    ricked's Avatar
    Apr 2016
    Europe
    "dont" take short cuts, de solder, if you "activate" surrounding components on the board while reading the eeprom you will end up with corrupted readings
  16. The Following 2 Users Say Thank You to ricked For This Useful Post:
  17. #88
    Aug 2020
    What exactly do I need to enter on lines 10/20 for 8K0953568G?
  18. #89
    eprst's Avatar
    Jul 2011
    Russia
    Hello, I need help clearing internal fault code for steering angle sensor.
    Mechanical fault was repaired, but the fault does not clear.
    95080 8K0953568G 8K0 953 568 G
    Thank you!
    THANKS + REP if I help you
  19. #90
    wembleyhill's Avatar
    Feb 2009
    Quote Originally Posted by eprst View Post
    Thank you!
    your file clear
    use buttons
  20. The Following 3 Users Say Thank You to wembleyhill For This Useful Post:
    Adi202 (12th March, 2024), eprst (11th August, 2020), lfpossamai (13th October, 2020)
